I'm building a fabric plotter/cutter and will be using a a relay with pneumatic valve to control my z axis.
Is it possible to use the z axis direction pin to control the relay? I could use an aux port but want to have the tangential knife to lift a blade in tight corners (tanknife z-up angle above a certain degree).
Thank You
