586,047 active members*
3,741 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > TS15 Turret Index Error After Power Cycle
Results 1 to 7 of 7
    Jan 2016
    Unhappy TS15 Turret Index Error After Power Cycle
    First off, great forum/community!
    My Hitachi Seiki TS15 lathe APC battery was replaced. After that, turret position was off and threw an index error. I would then move the turret by hand to T01 (could feel a pin sliding into place), remove the APC battery, set parameter 1815 bit-4 to 1, power off/on, MDI T0100 (turret makes a clicking sound), and turret position is OK and machine runs as normal. THen when I power off/on, the turret will index 2-3 positions beyond, throw an error and turret indexing is jerky. I do the same process again and the turret and machines runs fine until it gets powered off.
    It seems that the turret is losing some position memory after power-off. The APC battery is new and no errors/warnings are generate. Nothing needed to be re-aligned after the battery change but am I missing a step? Any help or ideas will be greatly appreciated!
    Dec 2009
    539
    Re: TS15 Turret Index Error After Power Cycle
    You also need to change PRM1015 and K00.3 from to do this procedure correctly. PM me if you still need help and I can send you some procedures on how to do fix this.
    John
    Apr 2013
    24
    Any further progress with this. I am having the same issue with the same machine.
    Jan 2019
    Hi. I have this issue again. Can someone send me the procedure?
    Dec 2009
    539
    Sent to your email - take a look
    John
    Jan 2019
    Looks I have similar problem:
    Please, advise how to reset Alarm 2011 (Index Not Ready) on Amera Seiki Fanuc O T
    Axis Z, X movable. Machine goes to HP. Turret not rotating Spindle not rotating.
    Spindle servo shows -- not 00
    Jun 2018
    20
    Quote Originally Posted by shas595 View Post
    John
    john please concact me very urgent!!! [email protected]
