586,036 active members*
3,938 visitors online*
    Jun 2008
    262
    USB Breakout board with LinuxCNC ??
    Hello,
    I'm not current on this topic. Is there a breakout board which uses the USB cable only for the motion data out there? We've had a computer go down and getting one with a printer port is possible, but desirable?? no
    Also if I have to use the USB in the computer do those adapter cables work for USB in the computer to the DB25 in our current breakout board?
    Nelson
    i build the braces that keep american teeth straight......tick tick tick
    Feb 2008
    644
    Re: USB Breakout board with LinuxCNC ??
    Quote Originally Posted by nelZ View Post
    Hello,
    Nelson
    No, other than some experimental branches, as far as I know LinuxCNC does not support any USB motion cards.
    This is because LinuxCNC runs in real time and all motion control is done in the host PC not the motion card.
    Reliable real time access to USB hardware is quite difficult...
    LinuxCNC does support Ethernet (and EtherCAT) connected motion cards however.
    If you are just repairing a system with a failed PC that has a parallel port interface to your hardware
    Is probably easiest to stay with parallel port hardware, since that will need the fewest configuration changes
    Jun 2008
    262
    Thanks a lot.
    Are there serial RS232 breakouts out there, and does LinuxCNC talk to them?
    Feb 2008
    644
    LinuxCNC can use Modbus (for I/O and VFD control) but not for realtime coordinated motion
    Though Modbus is most commonly RS-485 not RS-232
    There is realtime LinuxCNC compatible hardware for Parallel, Ethernet, EtherCAT, PCI, PCIE. and SPI but not USB
    Jun 2008
    262
    Thanks a lot! Something to google. I appreciate it.
  1. Help deciding which breakout board or driver board etc to use!
    By localbroadcast in forum Servo Motors / Drives
    Last Post: 06-09-2016, 09:25 PM
  2. Controller Board for LinuxCNC
    By Holzwurm56 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-30-2016, 08:58 PM
  3. BREAKOUT BOARD INTERFACE BUFFER BOARD
    By deslee in forum Servo Motors / Drives
    Last Post: 08-17-2014, 07:32 PM
  4. KL-4030 and C10 Breakout Board with KL23H286-20-8B motors and LinuxCNC
    By sbrendtro in forum Automation Technology Products
    Last Post: 04-04-2013, 03:35 PM
  5. LinuxCNC + USB breakout control
    By DiaLFonZo in forum LinuxCNC (formerly EMC2)
    Last Post: 10-01-2012, 03:15 PM
