586,055 active members*
4,459 visitors online*
Results 1 to 11 of 11
    Oct 2016
    128
    In need of assistance
    I'm trying to figure out the whole script for the tool change and I'm getting nowhere. My tool holder will be mounted to my y axis table and all movements have limit switches. Is there anyone who could shed some light this way before I rip all my hair out.
    35538
    Re: In need of assistance
    Theres a sample and tutorial video on the machsupport.com site
    Videos & Tutorials - Newfangled Solutions
    Oct 2016
    128
    Thanks I'll give that a look
    Oct 2016
    128
    It now tells me this
    35538
    That's an error from the MSM screenset. If you tried to uninstall it, and didn't do it properly, it can cause all kinds of problems.
    Oct 2016
    128
    Yeah it had to do with other screen sets I had tried earlier.
    I'm now c fused of the var table and what the getoemdro(1200) is about. I have movement but it's not moving as it should. Is there something that has to be done with the dro's on the settings page?
    35538
    You need to explain a little better? Did you write a macro, and that's where you're having the problem?
    Oct 2016
    128
    I think where I'm getting confused is the tool in spindle dro. The line
    oldtool = get oem dro (1200)
    35538
    I'll have to look later to see what 1200 is.
    Oct 2016
    128
    I think it's the x tool change location in the settings screen
    Oct 2016
    128
    I'm trying to get my m6 to wait for input 1 to be active before it continues with the tool change. I have a Colombo relay for checking rotation. I can't get my m6 to wait for the input. It either skips over the line or it requires me to press cycle start after the system wait for command. Do you know what I might need to put in the code for it to end the system wait once the input 1 is active?
  1. need assistance
    By vladp in forum Mastercam
    Last Post: 05-21-2016, 04:29 PM
  2. Assistance
    By shovo khan in forum Mechanical Calculations/Engineering Design
    Last Post: 02-13-2013, 08:12 PM
  3. DIY CNC Assistance
    By mforbes6186 in forum Maintenance DIY Discussion
    Last Post: 09-23-2012, 10:35 PM
  4. Need assistance
    By Hari Kristianto in forum Engraving Machines
    Last Post: 03-01-2011, 05:15 AM
  5. Assistance Please!
    By LMRecruiter in forum Employment Opportunity
    Last Post: 10-06-2006, 02:38 AM
