586,313 active members*
5,028 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko g540 Y-axis causing fault
    Jul 2012
    8
    I have gecko g540 tha I am using on a harbor freight x2.
    This morning when I started it up the y-axis would not work.
    The stepper motor also did not warm up like the other motors. I have checked to make sure it is not the wiring by switching the y axis plug to the x-axis and it worked fine.
    I also noted that the g540 case directly behind the y-axis plug was very hot.
    After reading a post on cnc-zone I opened the g540 case and I switched the a-axis g250x3 into the y-axis location.
    Can the g540 run ok with only 3 drives in it?
    steve
    Apr 2004
    5740
    Re: Gecko g540 Y-axis causing fault
    Sure; if you're not using the A axis for anything else, you can just change the pin-out and swap it for Y. The Gecko won't care if a channel isn't being used. But you might order another G-250 drive, so you'll have a spare if this happens again.
    Andrew Werby
    Website
  1. GECKO G540 CAUSING MACH 3 TO CRASH
    By pimpbike in forum Mach Mill
    Last Post: 03-26-2014, 06:29 PM
  2. Gecko G540 stays in fault mode
    By rstrease in forum Gecko Drives
    Last Post: 11-19-2013, 01:05 PM
  3. Gecko G540 - New - Can't get fault light to clear!
    By Vogavt in forum Benchtop Machines
    Last Post: 12-31-2012, 03:19 AM
  4. GECKO G540 - Stuck in "FAULT" mode.. HELP!?!
    By CNC74 in forum Benchtop Machines
    Last Post: 02-06-2010, 09:37 AM
  5. Z axis sending G540 into fault
    By FandZ in forum Gecko Drives
    Last Post: 06-11-2009, 03:28 AM
