586,113 active members*
3,220 visitors online*
Results 1 to 7 of 7
    Aug 2013
    980
    Need help with multiple offsets in PP
    I am attempting to do my first multiple offsets in PP and am not sure how to input the references.
    Here is what I think I am suppose to do;
    - type in G54 in mdi
    - reference the part and set 0 in x y z
    - type in G55 in the mdi for the next part/reference.
    - reference the G55 part and set zero in x y z
    - continue for G56, G57 etc
    Does this sound right?
    Do I keep re-reference zero for each part assume PP will remember it?
    Thanks for any insight on how to do this.
    Btw,I am using sprutcam for my cam
    Jun 2014
    1780
    Re: Need help with multiple offsets in PP
    Quote Originally Posted by CadRhino View Post
    I only use g54 and make several parts using the one offset
    I draw them in cad with a known spacing export into sprutcam and set the ops for all the parts.
    One part can be drawn in cad then imported into sprutcam and using the transform function, it will do as many multiples as you set up.
    I flip my parts for the back side but they are all still attached to the stock, machining the backside cuts them into individual parts and finishes them on a fixture.
    I have never used different offsets, I always work with g54.
    I use Sprutcam 7 here and Rhino 4
    mike sr
    Aug 2013
    980
    Thanks Mike,
    I want to learn multiple offsets sine I have a 3- chuck mounted fixture plate and every time I load it on the machine it will not be perfectly located so I want to reference each part independently (i.e. G54, G55....)
    QUOTE=popspipes;2084014]I only use g54 and make several parts using the one offset
    I use Sprutcam 7 here and Rhino 4[/QUOTE]
    Aug 2009
    294
    Are you re-referencing the machine for each offset? Your sequence looks good except I'm not sure what all the referencing is for.
    Once you reference the machine, set your G54 zeros. Then type G55 in your MDI and zero that. Repeat for the rest.
    Nov 2013
    402
    Yes, you're doing it right.
    There's no need to re-reference the machine.
    Just find your location and Zero X,Y. But make sure the corresponding G54, G55, G56, G57 is highlighted in the work offset page when Zeroing your location.
    Aug 2013
    980
    Thanks, I meant reference the next part, not re-reference the machine.
    Quote Originally Posted by C*H*U*D View Post
    Aug 2009
    294
    Gotcha! Then like Russ says, you're doing it right.
  1. multiple work offsets
    By poster in forum Mastercam
    Last Post: 02-21-2013, 03:28 PM
  2. Using multiple work offsets in MC
    By Crashmaster in forum Mastercam
    Last Post: 08-25-2010, 04:18 PM
  3. Multiple C-axis offsets?
    By bman356 in forum G-Code Programing
    Last Post: 04-03-2009, 10:17 PM
  4. Multiple offsets
    By Tinker Simpleto in forum Haas Mills
    Last Post: 12-05-2008, 02:01 AM
  5. Tl-25 multiple offsets for same tool Help
    By mkmk123 in forum Haas Lathes
    Last Post: 11-24-2007, 01:22 AM
