586,103 active members*
3,278 visitors online*
    Jul 2017
    100w laser cutting intermittently!!
    Hi again all, so last night i began to cut a few things and straight away i noticed my laser would not fire when supposed to.
    The head is moving correctly for the cut but no pulse from the laser.
    Example: when cutting a circle the head starts at the top centre and moves around but it only started to cut about 1/4 of its way round.
    Cooling is all ok and flow sensor is functioning.
    Im using a universal laser with 100w reci tube and sinjoe awc608c plus controller.
    Can anyone possibly help me out ???
    Re: 100w laser cutting intermittently!!
    What software are you using?
    From what I see, it should be something wrong with the pulse.
    Try to reset the parameter and see if it will work.
    Best of luck
    Achilles
    www.gurulaser.com
    Nov 2010
    787
    Universal Laser with Reci and sinjoe awc608c ???
    Can`t be truth.
    CNC lasers, constructions, service
    Apr 2018
    20
    [QUOTE=Rhys_Mack;2079096]Hi again all, so last night i began to cut a few things and straight away i noticed my laser would not fire when supposed to.
    Can anyone possibly help me out ???[/QUOTE Hi my friend first you have to check whether laser tube is working.Please make a laser spot on acrylic directly.
  1. 100w Laser won't cut
    By KenR60 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-14-2016, 11:32 AM
  2. 90-100W laser tube
    By laser tube in forum For Sale Only
    Last Post: 05-22-2015, 02:44 PM
  3. 80-100W laser tube
    By lasertube in forum Commercial Laser
    Last Post: 02-25-2015, 06:23 PM
  4. 100W laser engraving/cutting machine
    Last Post: 06-11-2014, 06:30 PM
  5. New power of 100w fo CO2 laser engraving and cutting machine
    By vivinar in forum News Announcements
    Last Post: 10-21-2010, 02:09 AM
