586,477 active members*
3,876 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Transporting a Fadal TRM
    Oct 2014
    10
    I just purchased a Fadal TRM for my home shop and am working figuring out how to correctly transport it. As such, I have a couple of questions. First, what is the correct way to block the head for transport? Finally, where is the best location on this machine to attach straps to tie it down on the truck?
    Thanks!
    Jan 2015
    417
    Re: Transporting a Fadal TRM
    Should be 2 holes in side of column jog the head and they will line up withe the column holes and slide in the steel bars thru the counterwieght to the other side of column from original delivery (lots of them get lost after years of sitting around)
    the base should have holes thru for chaining to truck they are also for lifting bars.
    talks about it in the maintenance manual http://itscnc.com/images/Installation_Procedures.pdf
    Oct 2014
    10
    Thanks for the response. I found that the TRM does not have a counterweight. So I blocked the head and moved it.
  1. Transporting a Cincom L25
    By Lene Madsen in forum CNC Swiss Screw Machines
    Last Post: 12-04-2015, 10:56 AM
  2. Transporting Machines
    By Whizbang in forum Benchtop Machines
    Last Post: 08-18-2013, 02:39 AM
  3. Transporting a CNC mill
    By Rick_B in forum Uncategorised MetalWorking Machines
    Last Post: 12-06-2012, 09:35 PM
  4. Transporting BMC 20
    By battman in forum HURCO
    Last Post: 02-27-2012, 02:56 AM
  5. Bp s2 r2e3 transporting? Decent deal?
    By chevyracer5613 in forum Bridgeport / Hardinge Mills
    Last Post: 02-13-2010, 03:02 PM
