586,072 active members*
4,476 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 110v 2.2kw VFD/spindle help
Results 1 to 19 of 19
    Nov 2009
    42
    Hey guys,
    I purchased a 110v 2.2kw spindle and vfd from buildyourcnc.com recently and just got around to installing it. I cannot tell the brand of vfd and all the parameters in the small user guide are in Chinese. I set up and programmed the vfd per the site instructions. All air cut tests have been successful. However when I try taking wood test cuts the motor loses power dramatically. I am replacing a porter cable 7518 with this. I ran a proven program using the same whiteside 1/2" carbide spiral bit with .150 doc @ 75ipm with 18k rpm/300hz in northern ash. Now the vfd and spindle both have 8.5 amps on them. I programmed the vfd at 8.5 amps per the website instructions. But logic tells me that the input amps should really be 17 amps at 110 volts. I set the vfd to 16 amps input voltage and the spindle still bogged in the full width cut. Rpms increased to what sounded like full power when it was doing a 40% step over but would then stall when it was taking a full width cut.
    Do you guys have any ideas?
    Thank you advance
    Chris
    Jul 2016
    660
    Re: 110v 2.2kw VFD/spindle help
    Can you post a video of the spindle stalling during work? a picture of the VFD too, 2200W is a lot of power on my opinion.
    15362
    Quote Originally Posted by factory5150 View Post
    Hey guys,
    I purchased a 110v 2.2kw spindle and vfd from buildyourcnc.com recently and just got around to installing it. I cannot tell the brand of vfd and all the parameters in the small user guide are in Chinese. I set up and programmed the vfd per the site instructions. All air cut tests have been successful. However when I try taking wood test cuts the motor loses power dramatically. I am replacing a porter cable 7518 with this. I ran a proven program using the same whiteside 1/2" carbide spiral bit with .150 doc @ 75ipm with 18k rpm/300hz in northern ash. Now the vfd and spindle both have 8.5 amps on them. I programmed the vfd at 8.5 amps per the website instructions. But logic tells me that the input amps should really be 17 amps at 110 volts. I set the vfd to 16 amps input voltage and the spindle still bogged in the full width cut. Rpms increased to what sounded like full power when it was doing a 40% step over but would then stall when it was taking a full width cut. Build your cnc.com hasn't exactly been helpful so far. Each day I'm down loses serious production.
    Thank you advance
    Chris
    The Parameters for the spindle is what you set in the VFD 9 amps is max for this spindle, so your VFD should not be set above this number, you will smoke your spindle with 16 amps set
    Do you have this on a 25A to 30A amp circuit for the input power your 120v would need to be a minimum of 25 amps, a standard 15 amp circuit is not going to do it, this is also a bad idea for a 2.2Kw spindle the VFD should of been for 220v / 240v input supply voltage
    1.5Kw is about the limit if someone only has 120v supply
    Mactec54
    Nov 2009
    42
    This is on a 20 amp circuit. It only ran at the higher amps for less than 30 seconds. Verified the settings for the 4th time and set the amps back to 8.5 and shot this video.
    https://youtu.be/sbOd8830D6I
    I understand due to my input voltage that I will never see the power it could using 220 but I didn't think it would be this bad. I have trim routers with more balls than this. So if this is as good as it gets I guess ill need to sell this setup, call an electrician to rewire my tapped panel and get a proper 220v vfd/spindle.
    I was lead to believe that you can program the input and output amps to control the ceiling of power it will consume.
    15362
    Is the spindle marked 120v or 220v
    Does not sound good at all
    Mactec54
    Nov 2009
    42
    Spindle is stamped 110v just like the vfd. So am I not crazy thinking something is wrong with this picture lol.
    Jul 2016
    660
    How many mm is your cut depth on the video? and what tool bit? sounds like too much drag it almost like braking the spindle RPM, if you have a clamp meter try to read how many amps. while on that dragging sound. on that we can tell if it`a a wrong setting on the VFD or it`s just too much for the tool bit to cut causing it to drag on the material, is the tool bit in a correct rotation?
    Jun 2010
    4256
    This is a 'low-price' Chinese VFD, yes?
    Cheers
    Roger
    Nov 2009
    42
    Quote Originally Posted by KH0UJ View Post
    I had that info in the first post. 3.8mm depth of cut using a brand new Whiteside ru5200. I have been using these programs for years without issue running on my old porter cable 7518 setup. Spindle is rotating the correct direction, that was one of the first things I checked.
    I only have a multimeter with probes, not alligator clips. Where would I put the probes to test how many amps during a load?
    And yes I suppose this would be a cheap vfd, but guys run cheap eBay vfds all day long. Is it going to have the longevity of the good ones? No, but the price point doesn't reflect that either.
    Jul 2016
    660
    No sir you cant probe an AC line for amperage using a multimeter, unless you have large AC amp meter to connect it in series on the lines, an AC clamp meter is the most convenient one, I wanna compare it on the shop`s spindles because it`s also a china water cooled.
    15362
    110v 3ph 2.2Kw would be a dog, only the Chinese would do such a thing to try to get extra sales / business
    The problem is your spindle can't be 2.2Kw @ 8.5A that would need to be 20amps at 110v to run correctly, so what you have is a less than 1Kw spindle running at 8.5A on 110V
    So your router you where using was more powerful than what you have, you would have to take lighter cuts for this to work
    Mactec54
    15362
    No amount of checking the Amps will help at all, a 2.2Kw spindle running on 110v would have to be rated at 20Amps Not 8.5 Amps
    Mactec54
    Nov 2009
    42
    Buildyourcnc.com is standing behind the product and I'm swapping this for the 220v version. Should be good to go once I get the new parts and the electrician out to do the install.
    I appreciate the help fellas.
    Chris
    15362
    Chris
    He would have to stand behind it, he should not be selling it to start with, I hope others read this and not buy any of the 110v 3ph spindles, they are a bad deal
    Mactec54
    Jun 2010
    4256
    Even so, 220 V x 8.5 A = 1.87 kW. Not really enough to drive a 2.2 kW motor, especially after allowing for some efficiency losses.
    Cheers
    Roger
    15362
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    They are really 220v/240v @ 10A not 8.5A
    Mactec54
    Jun 2010
    4256
    I was going on the OP's comments in posting #1 and subsequent.
    Cheers
    Roger
    15362
    Cheers
    Roger
    The manufactures rate the Amps lower than they should be for most of these spindles, some have 10A some 9A some 8.5A there where some that had 12A all for the same spindles same Kw rating
    Mactec54
    Jun 2010
    4256
    Sounds like caveat emptor.
    Perhaps there is more tech knowledge here than with some vendors?
    Cheers
    Roger
  1. 220V spindle / VFD from 110V input?
    By nplayle in forum Spindles / VFD
    Last Post: 08-12-2016, 04:43 AM
  2. 62mm 110V Spindle
    By Bob La Londe in forum Want To Buy...Need help!
    Last Post: 06-08-2016, 07:03 PM
  3. 110v 1.5kw VFD & Spindle Producing a Shock
    By Parke in forum Spindles / VFD
    Last Post: 04-19-2016, 05:20 PM
  4. PC 7518 vs 1hp HSD 110v Spindle
    By firewire in forum Commercial CNC Wood Routers
    Last Post: 12-31-2014, 03:02 AM
  5. Spindle motor and VFD for 110v
    By shadowless in forum CNC Machine Related Electronics
    Last Post: 03-26-2009, 04:51 AM
