586,104 active members*
3,470 visitors online*
    Apr 2003
    95
    6040 height setting the Z axis
    Hello Group, I have a Chinese made router and I was wondering when using the height setting gauge, is there anything I have to setup in Mach3 for it to work or after I plug it into the box will it just work?
    Eric
    Sep 2016
    20
    Re: 6040 height setting the Z axis
    I don't know the answer to that but would like to.
    I've just been setting the cutter tip on the surface using a page from the phone book, and manually entering the necessary Z dimension on Mach3 to suit the program.
    Cheers
    Jun 2005
    1730
    The first question is do you have an open input pin? If you do there are many scripts for Mach3 that will allow you to use a height setting gauge. Check on your controller which is probably parallel port based and see if you have an available input pin. If you do it is very easy to add a script in Mach3 to do height sensing. There are many videos on youtube and instructions on the zone, just look in the Mach3 forum.
    Russ
  1. Setting up 4th axis on Chinese 6040 CNC Router
    By ecope in forum Chinese Machines
    Last Post: 10-30-2016, 03:47 PM
  2. CNC 6040 Setting or Other Issue - HELP!
    By DeeMaster in forum Mach Software (ArtSoft software)
    Last Post: 01-24-2016, 11:16 AM
  3. Setting the Z axis tool change height
    By TR MFG in forum Fadal
    Last Post: 11-07-2009, 04:22 AM
  4. Setting up Z axis tool holder height above table
    By EL34 in forum DIY CNC Router Table Machines
    Last Post: 07-27-2007, 09:28 PM
