586,106 active members*
3,303 visitors online*
Results 1 to 3 of 3
    Dec 2007
    6
    Unhappy I need help with my cnc
    I need help with my cnc . I builted mine and it has been running very good. I am running Mach3 & cambam . I st started to have a problem with the z axis I can't zero the zaxis it will go down but it won't go up when I manual
    try to move it up I can't use the key board or the remote the z axis works fine when I run a program to cut something . Is there anyone that can help?
    Apr 2004
    5737
    Re: I need help with my cnc
    Could it be a problem with your keyboard? Have you tried plugging in another one?
    Andrew Werby
    Website
    Apr 2008
    204
    hit the tab button and make sure the jog feature is in cont and not step. That is normally what happens to me. It makes you think it isn't working, but you are only telling it to move whatever the step is set to.
