586,067 active members*
5,254 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Using a 230V VFD with 120V
    Jul 2017
    5
    I recently got an X3 mill for cheap because the spindle motor is not working. I am doing a CNC conversion and I think I will replace both the spindle motor and controller board with something I can control from my motion controller board.
    I have a big pile of parts in the garage, and one of them looks to be a pretty nice VFD. It is a Siemens Micromaster Vector 6SE3215-2CB40. I am including an image of the specs printed on the VFD.
    It is rated for 1.5HP/1100W output, which seems like a useful range for the X3 mill spindle motor, but it is rated for a 230V input, and the house I am renting only has 120V available in the garage. I don't think I have the option of changing the garage wiring, so I am wondering if I can make this VFD work.
    Three options:
    1. Use a 120-240V transformer (it will have to be very big...) to supply the VFD
    2. Try running the VFD with an input voltage of 120v
    3. Sell the VFD and buy one designed for a 120V input.
    I don't have a lot of experience with VFD's, so I am not sure if #2 is even an option. I also don't know for sure that this VFD even works (I think it was removed from working equipment, but it has been sitting for 3-4 years), so I will also need to learn how to get it setup.
    May 2013
    480
    Re: Using a 230V VFD with 120V
    you can wire a 1KW 120v:120v isolation transformer as a voltage doubler, it will be good for 2KW worth of 240vac which will be enough for your vfd and spindle.
    another option is buying a diode block and some 200 volt electrolytic capacitors to build a voltage doubler (4000 uF worth perhaps, two of them), feed that voltage into your vfd.
    15362
    Quote Originally Posted by ravix View Post
    Three options:
    Of your choices the Transformer is your best why to go as many have done, something like this is all you need, you could run your whole machine from this one source, having a 120v and 240v output
    https://www.amazon.com/2000-Voltage-...ansformer+2000
    Mactec54
    Jul 2017
    5
    Thanks! I bought that exact transformer and will try using it.
  1. Do spindles run on 120V?
    By Merlysys in forum Spindles / VFD
    Last Post: 10-16-2015, 09:49 PM
  2. LS iC5 230V 1.5kW Inverter
    By neurofen in forum CNC Machine Related Electronics
    Last Post: 02-03-2014, 07:03 PM
  3. 200V cooling fan on 120V
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 02-02-2012, 05:00 PM
  4. Yet another 120v to 220v
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 02-24-2006, 08:57 PM
  5. 120V Stepper - how can it be driven?
    By andy_ck87028 in forum Stepper Motors / Drives
    Last Post: 07-17-2005, 09:16 AM
