Re: question on hooking powermax 45 xp machine torch to G540 and proma THC asap pleas
I don't know your hardware or machine but you would need to use an output to trigger a relay. The contactors on the relay would be connected to the start plasma pins in the CPC socket. If the Gecko has a relay built in, I guess you could use that but for a few $ I'd keep any wires from the plasma cutter off my controller just in case something went wrong (which could be expensive to replace)
Normally, the plasma cutter will send a signal back to say it has a good arc (Arc OK). It looks like pins 12 and 14 do this. The plasma cutter will have a relay on these wires that closes when you have a good arc. You you'd take a common voltage, connect it to one of these pins and then connect the other one to an input on your hardware.
Remember you can't just send a signal to and from different machines. You need to use relays to switch signals.
Rod Webster
www.vehiclemods.net.au
