Originally Posted by
clc2112
I have:
OneFinity CNC. with the
Huanyang 2.2kw water-cooled spindle VFD combo.
I've connected the spindle to the VFD and am able to control it and spin it up via the VFD panel. I connected the remote control wire on the VFD RS+ and RS- to the appropriate connections on the breakout box. (13 and 14). I am getting an "ok" in the connection status.
However, once I connected the breakout box to the onefinity controller and all settings below are set in the VFD it simply doesn't spin up. As soon as I send M3 S4000- it immediately throws the "E.AC.0" error on the VFD. I've no clue why and what the next steps would be, Again the spindle spun up nicely from the VFD control panel until I connected it to the controller.
Any thoughts?
PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
PD001=0 (1 For Remote Control)
PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control ) ( J1 Also Needs to be set for Terminal Control )
PD003=400
PD004=400
PD005=400
PD007=20
PD008=220 (Motor Rated Voltage )
PD009=15
PD010=8
PD011=120 ( 100 Minimum Setting with Quality VFD, 120 is Safe)
PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
PD014 Acceleration=12 ( Adjust to suit)
PD015 Deceleration=12 (Adjust to suit)
( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
PD141=220 ( Motor Rated Voltage )
PD142= 9 ( Motor Amp Rating 2.2Kw Spindle 9 amp )
PD143=2 ( Motor Number of Poles)
PD144=3000 (Max Motor RPM) =3,000= (24,000)
PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
PD72=400
PD73=120 ( 100 Minimum Setting )
