586,070 active members*
3,543 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > CNC Plasma / Oxy Fuel Cutting Machines > want to convert my router to a plasma table need info on plasma setup
    May 2016
    hello i own a 4x8 gryphon router table thats great for wood an what not but i have some larger plate metal id like to start playing with an it simply cant handle to load. i own a older plasma cutter already and if possible would like to retrofit it to this table. so if anyone could point me towards what i may need id appreciate it.
    May 2015
    686
    Re: want to convert my router to a plasma table need info on plasma setup
    You will face a couple of issues:
    1. Generally plasma needs to be light and fast v's heavy and slower like a router.
    2. Your older machine probably does not have a CNC port but there are ways around that
    3. Your older plasma cutter probably uses high frequency start which is hard to manage with CNC due to the electrical noise it generates. Pilot arc or blow back torches are better.
    Normally you would want a torch height control module. This will require a voltage divider to be fitted. If you are only cutting thicker plate, you may get away without it.
    Ata simplistic level, you could probably just mount your torch and add a relay to turn on the torch under CNC control
    Normally Plasma's return an Arc OK signal to the CNC controller to tell the machine it has a good arc and can start cutting but as a simple solution, its not necessary.
    So at the most basic level, attach the torch to your Z Axis, touch off in the normal way than run some gcode to raise to pierce height, wait for pierce delay and then drop to cutting height and start cutting.
    PLasma is however much more complex than this to build a robust machine.
    Rod Webster
    www.vehiclemods.net.au
  1. OMNI CNC New plasma table setup
    By carterjv8 in forum Chinese Machines
    Last Post: 07-01-2017, 07:26 AM
  2. bought a plasma table a while ago - looking for advice on upgrades, setup, etc.
    By sewerzuk in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 04-15-2016, 11:18 PM
  3. Can I convert HF plasma to arc pilot plasma??
    By abed in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-09-2011, 12:15 PM
  4. Can i Get Info on a Chinnese Plasma Table
    By dcp in forum Waterjet General Topics
    Last Post: 12-21-2008, 08:04 PM
  5. Replies: 0
    Last Post: 11-09-2004, 11:00 PM
