586,055 active members*
4,357 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal bad arc finish
Results 1 to 16 of 16
    Hi friends
    I have two fadal 4020 and many problems
    All of arcs very jerky and i think bad finish
    And angles have stair step finish
    On manual of fadal wirten this problem for motor
    AXIS AMPLIFIER
    COMPENSATION
    SETTING
    And
    CHECK SIN/COS
    SIGNALS USING
    SERVICE TOOL ST48.
    ADJUST IF VARIANCE
    > 0.001V
    But how adjust sin/cos output from clock card?!!
    I checked all 3 axis resolver and tach and very clean
    I check all 3 amplifiers and balance and signal gain adjusted
    I check comp and cl complete cw( not multi turn pot)
    Checked 5vdc & 12v is good
    Checked big blue capacitor and 125vdc output for motor drives
    Adjusted master clock feedrate with r6 pot
    What is the way clock card sin/cos output setting?!!!
    All 3 cuopling is ok and ballscrew rebuild
    Gib belts is ok
    But when interpolating x&y axis bad moving axis and
    I think not sync
    Please helps
    Thx:
    Sep 2004
    148
    Re: Fadal bad arc finish
    Quote Originally Posted by Mhook View Post
    Hi friends
    AXIS AMPLIFIER
    COMPENSATION
    SETTING
    And
    CHECK SIN/COS
    SIGNALS USING
    SERVICE TOOL ST48.
    ADJUST IF VARIANCE
    > 0.001V
    Gib belts is ok
    I think not sync
    Please helps
    Thx:
    Hi Mhook
    I had the same issue
    I had to adjust the clock card to get the correct 72 seconds +1.5/-0.0, after which I had to adjust the following error to 595. That didn't improve the finish.
    I would say it's 95% likely you have a bad resolver(s)
    The resolvers on the X and Y axis were bad, the bearings in the X-axis allowed very large amounts of radial and axial play. I bought some small bearings from McMaster and made housing disks to replace the bearings of the resolvers. That fixed the issue. I bought 2 new resolvers off ebay, which I will replace the fixed resolvers with.
    Pull the resolvers off and check the bearings.
    hi triumph 406
    thanks for your time
    I replace 3 resolver
    also i check 1.75 vac on axis controller cards its fine
    i check resolver bearing very smooth turning and resolver bearing is good
    by the way i replaced with new resolvers on x&y&z motors
    but my problem not solved
    i checked ac ripples on power supply 5,-12,12 and under .02 vac
    i think this problem for droping output voltage on amplifiers
    or bad comp
    and clock card sincos output signal
    all of 15 years with fanuc ,siemens,mitsubishi,heidenhain working i never have problem for arc machining but with
    fadal control i have only problem problem and problems on arcs
    tach feedback
    x 3.4
    y 3.35
    z 3.9
    for 500 rpm on motors
    Sep 2004
    148
    Mhook
    sounds like there may be some mechanical issues
    Is it getting adequate lubrication to the ways?
    Gibs correctly adjusted?
    Machine level?
    Hi
    Yes
    Gib adjusted with pulbar .007 mm and ballscrew
    Free moving by hand
    Machine table is level
    All 3 axis bl under 5 value
    Lubrication is ok
    Box way always lubricating
    Jan 2004
    3154
    it could be the program.
    Maybe your other controls have built in "short segment smoothing".
    www.integratedmechanical.ca
    Apr 2016
    74
    try this, run it at a 45 deg. angle and watch the numbers next to the x and y, they should be the same and a low number.
    if not the servos are not tuned correctly, we usually bring a service tech to fix that, but it fixed the problem your describing.
    Hi JMORLAN
    I dont trying 45deg
    But certainy i check that
    Already i checked following error on 302 & .735 vdc all 3 axis
    425 & 1.04 vdc and 595 & 1.44 vdc on all 3 axis
    But didnt improve arc finish
    I try 45 deg and i tell you
    Thx
    Sep 2004
    148
    Hi JMORLAN
    I dont trying 45deg
    Thx
    Mhook
    In one of the online Fadal manuals (can't remember which) there's a procedure for setting the following error. For a 4020 it goes from along a diagonal line, I think it was X-10,Y-10,Z-10 TO X10,Y10,Z10 at 100ipm. You run this and set the following error to 595
    Thx triumph 406
    I usually type TA,2 and Service programs upload
    From eprom to memory
    next run program number 5811
    For adjust following error
    CHECK SIN/COS
    SIGNALS USING
    SERVICE TOOL ST48.
    ADJUST IF VARIANCE
    > 0.001V
    Adjust clock card ?!!!
    Sep 2004
    148
    Jmorlan
    I checked 45 deg and all of numbers on display identical x&y
    When i remove power supply and check with oscilloscope on -12 vdc
    ac ripple = .35 vac
    Does it ok?!
    I thinks capacitors destroyed
    Please help
    Thx
    A bad capacitor will be visible, usually swelling of the body or cap
    Apr 2016
    74
    This might be something to try, that has caused us issues in the past, have you checked your bellville washers? put a indicator on the toolholder in the spindle and use a pry bar and see if you can move the toolholder, if you can, you need to replace those. your not getting
    any drawbar pull. just a shot..............
    Sep 2004
    148
    bad electrolytic capacitors will be visible, either swelling of the body, or swelling of the end of the capacitor.
    CHECK SIN/COS
    SIGNALS USING
    SERVICE TOOL ST48.
    ADJUST IF VARIANCE
    > 0.001V
    Adjust clock card is my dream
