586,269 active members*
3,453 visitors online*
Results 1 to 8 of 8
    Aug 2017
    13
    Home build CNC
    Hi i am new to CNC zone..i am building a small CNC machine for use as a driller router for PCBs similar to a you tube version from NYC CNC but using Mach3 driving breakout board and motor drivers..my question is the wire from the motor drive boards to stepper motors what gauge of wire should i use and does it need to be screen cable..grateful for any help.
    Regards John
    Re: Home build CNC
    Depends on how big your motors are, but 18 gauge is probably fine, and shielded is not required, imo.
    Aug 2017
    13
    I am using Nema 17 for X and Y and Nema 23 for Z
    JOHN
    Re: Home build CNC
    I've been using unshielded 22 awg on my Nema 23's for 10 years.
    Aug 2017
    13
    Re: Home build CNC
    Thanks for reply, I had heard you can get noise from un-earthed cable but that probably on a wood construction machine but I am building with Aluminium, I started original design using Arduino and CNC Shield but decided to change to using Mach3 so was easier to use Beakout board and Stepper drivers and speed control for Spindle and then I can use G-Code from Eagle PCB design software, not started build yet need a Pillar drill first to help with construction got most of the other bits.
    Regards John
    Re: Home build CNC
    You might want to consider UCCNC, rather than Mach3. It's cheaper, and better.
    Aug 2017
    13
    Re: Home build CNC
    Yeh I looked at UCCNC it looks very good but then I found 1 drawback for me, you need to purchase a UC100 serial to parallel dongle and that will set you back anything from £80 to £120 so cost of software about £50, but I think I can get away with using Mach3 Demo as it gives you 500 lines of G-Code that may be enough for me, we will see.
    I am retired so don't have too much money so that extra on software may break the bank, will suck it and see. LOL
    John
    Sep 2009
    15
    Re: Home build CNC
    Have you looked at linuxcnc as a controller out is free a bit of a steeper learning curve then mach 3 but more powerful.
    Sent from my HTC One_M8 using Tapatalk
  1. Router home build Australia. Solid steel build
    By 80gus in forum DIY CNC Router Table Machines
    Last Post: 05-03-2020, 09:24 AM
  2. Hi all - new to CNC and need a little help with my home-made build.
    By dchurch24 in forum LinuxCNC (formerly EMC2)
    Last Post: 04-28-2015, 12:50 PM
  3. SX3 CNC Home build info please.
    By ChrisRTerry in forum Syil Products
    Last Post: 07-12-2014, 10:14 PM
  4. cnc home build
    By 88rob88 in forum DIY CNC Router Table Machines
    Last Post: 02-18-2012, 02:59 AM
  5. FAQ's for Home Build Lasers
    By ViperTX in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-04-2005, 04:16 PM
