586,246 active members*
3,767 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > CNC LATHE THREAD (SCREW CUTTING)
    Aug 2012
    126
    Hi All,
    Can anyone help?
    I am trying to create a 20mm x 2mm pitch thread on low carbon (free cutting) Mild Steel, I am getting a poor finish? under a magnifying glass the surface looks "torn"
    I have tried several small cuts (0.10mm) different spindle speeds (up to 400 Rpm, obviously I have no control over the feed as the acceleration rate is controlled by the spindle speed,
    I have tried leaving just 0.05 to 0.075mm for a final finish cut using a different offset in the tool list,
    I am using a coated ER-AG60 Insert flooded with coolant, strangely HSS worked better but the tool life deteriated quickly and I have quite a few to do,
    Can anyone give me any hints on spindle speed, insert (Tip) type?
    At the moment I am having to leave them plus on dia and then run a die down them and my arms are starting to hurt!
    Thanks for any advice,
    Allen.
    Nov 2007
    479
    Re: CNC LATHE THREAD (SCREW CUTTING)
    you have the right shim? I would try going faster rpm like 1500-2000
    Aug 2012
    126
    Hi djr76,
    Thanks for you help, the right "shim"? by this do you mean the cutting insert?, and 1500 Rpm, that will be pretty scary watching the z axis move at a 2mm pitch rate, that sounds fast!
    I have got up to 500 rpm and then lost my bottle because the federate looks bloody quick!
    Thanks again for your help,
    Allen
  1. Lathe thread cutting problem V26
    By billb95 in forum BobCad-Cam
    Last Post: 08-22-2014, 03:37 PM
  2. cnc thread cutting in sherline lathe ..
    By CNCpatriot in forum Mini Lathe
    Last Post: 09-06-2012, 07:52 AM
  3. Thread cutting Ikegai lathe
    By hammer28 in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2010, 02:54 AM
  4. Cutting thread on CNC lathe by Mach3 ?
    By jimmychand in forum Mach Software (ArtSoft software)
    Last Post: 01-22-2008, 06:12 PM
  5. Thread Cutting on MAXIMAT V10 Lathe
    By Kiwi in forum MetalWork Discussion
    Last Post: 06-18-2006, 06:32 PM
