586,035 active members*
3,720 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > Problem with my OKK Millcon III (MHA 400 & MHA 300)
    Jun 2017
    Question Problem with my OKK Millcon III (MHA 400 & MHA 300)
    I have two machine of OKK Millcon III (MHA 400 & MHA 300). Both has Meldas 83A controller
    The machine when bought was not in running condition and was idle for a while
    I tried to power up the machinery
    Both displays the same alarm E=20 when i try to power on the machine and release the emergency
    Moreover I tried to change the parameter which wasn't successful at all
    I have been told that it's a software related emergency parameter
    I'm not convinced with the reply
    I'm open to suggestions
    If needed I can send screenshots
    P.S. I have the original parameters. But i would like to know the parameter setting procedure. Because however we do it, we couldn't change the parameters other than the M list
    Kindly assist
    May 2008
    107
    Re: Problem with my OKK Millcon III (MHA 400 & MHA 300)
    Dear delicatev4.
    Did you solved this problem? If yes, could you give me the way to fix this( I have MHA300 machine with the same E20 alarm).
    Could you sent me the parameter: [email protected].
    Thanks for you help.
    Nam.
  1. Fadal Idler problem. Rpm pulse problem
    By complextool in forum Fadal
    Last Post: 10-07-2016, 06:28 PM
  2. software problem engraving problem please help
    By jassk in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-19-2014, 09:31 AM
  3. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 04:09 AM
  4. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  5. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
