586,121 active members*
3,755 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > Using V Carve Pro on a Milling Machine
Results 1 to 6 of 6
    I have a Bridgeport Milling Center with a GE Fanuc Series 0-Mate M Controller.
    I'd like to know if anyone here has used V Carve Pro to program a milling machine like this. I don't see my exact controller listed in the post processors.
    Kevin
    Jun 2005
    1730
    Re: Using V Carve Pro on a Milling Machine
    CastleWorks,
    My guess is it will work just fine. You can output to many machines but think all you would need to do is set it to generic fanuc output and it will work just fine. I can probably send you a simple output file from vcarvepro, nothing fancy and output it to generic fanuc and you can do a quick test.
    Russ
    Mar 2008
    1762
    Kevin...
    I have a CNC upfitted BP series 2 running WinCNC and its my "Daily driver". I use it to cut components for small CNC's and retrofits that I do. All design and toolpath is done with VCPro
    Some pics here: Latest Project
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Feb 2009
    192
    Quote Originally Posted by CastleWorks View Post
    Kevin
    CNCMAN172 is probably correct with the using the generic Fanuc post-processor. Just select the appropriate work units for your application and run a small test fill to confirm it's operation.
    Thanks, good to know. I am still working on getting the PC connected up to the CNC through the serial port in order to load a program. Once I clear that hurdle I will try a test program.
    Hi All,
    Update....I can successfuly load a program to the controller. I am using VCarve 6.5 and tried both the Fanuc16 ATC and the Fanuc0i ATC post processors. Most of the programming works fine but it hangs up when it goes to change tools. Essentially it moves to the tool change height and stops but never proceeds to change tools.
    Do you know if there are other Fanuc post processors available for VCarve Pro? Can the post processors be edited?
  1. Scale problems from V carve PRO to machine
    By DigitHead in forum WoodWorking Topics
    Last Post: 08-14-2014, 04:32 AM
  2. Which type and the right tools to carve or machine
    By adrtan8 in forum CNC Machining Centers
    Last Post: 01-26-2011, 10:01 PM
  3. CNC Milling Machine Packages and Bespoke CNC Milling Machines
    By worldofcnc in forum News Announcements
    Last Post: 05-27-2010, 02:20 PM
