545,690 active members*
2,527 visitors online*
    Registered
    Dec 2007
    77
    BACKSAVER SHELF
    Here are some pictures of a simple shelf to reduce your back strain. The shelf is made of 3/4 " MDO supported by those ubiquitous shelf brackets from Home Depot. The table is placed at its furthest cross position and its furthest tailstock position. The shelf is mounted so that it is flush with the top of the mill table and even with the side. You can now keep those heavy items like CNC toolpost, CNC rotary table and milling vise on this shelf. When you want to use one, just run the table down to the the shelf and slide your tool on with no lifting. This one is mounted to the wall, but if your machine is in the open, you could build a support that bolts to the bench.
    Attachment 370480 Attachment 370482
    Attachment 370484 Attachment 370486
    Member
    Oct 2020
    11
    Re: BACKSAVER SHELF
    Good sharing! Thank you JTJT!
  1. MWF Shelf Life
    By ornon in forum General MetalWork Discussion
    Last Post: 02-20-2009, 01:39 AM
  2. Off the Shelf Spindle
    By JerryFlyGuy in forum Mechanical Calculations/Engineering Design
    Last Post: 11-11-2006, 02:06 AM
