586,119 active members*
3,583 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 110v VFD's. Any issues?
Page 6 of 6 456
Results 101 to 106 of 106
  1. #101
    15362
    Re: 110v VFD's. Any issues?
    Quote Originally Posted by AngelArs View Post
    The neutral wire doesn't prevent ground loops per se, but buy using the neutral wire for my 120v it keeps everything coming from the same source, which does prevent ground loops.
    Correct
    Mactec54
  2. #102
    Sep 2005
    1740
    The neutral wire doesn't prevent ground loops per se, but buy using the neutral wire for my 120v it keeps everything coming from the same source, which does prevent ground loops. ?? Correct
    As long as your power source is coming from the same house or building Main breaker, your on the same source. Electrical wiring 101. A neutral wire connected or not has nothing to do with equipment grounding or loops. The green or green / yellow wire connected to the ground buss at the main panel is the only equipment ground. This is basics folks. The real electricians in the group understand, you do not. I will no longer post on this Thread but will let the electricians have a good laugh on your answer above.
    FYI > https://www.cnczone.com/forums/diy-c...-nec-nfpa.html
  3. #103
    15362
    Quote Originally Posted by wmgeorge View Post
    The laugh is on you I did not post that :wave:
    Now you are posting posts under my name that I did not post, you are really messed up, your link has nothing to do with this thread, I'm not sure what you are trying to commutate here but you are failing to understand what is being posted
    Mactec54
  4. #104
    15362
    For those that don't understand what a Ground loop is here is an basic explanation of what a Ground Loop is a snip below is a common one with home connections, the same applies with machines as well
    Ground Loop Basics
    What is a Ground loop ?
    A Ground loop occurs when there is more than one ground connection path between two pieces of equipment. The duplicate ground paths form the equivalent of a loop antenna which very efficiently picks up interference currents. Lead resistance transforms these currents into voltage fluctuations. As a consequence of ground-loop induced voltages, the ground reference in the system is no longer a stable potential, so signals ride on the noise. The noise becomes part of the program signal.
    Ground loop is a common wiring condition where a ground current may take more than one path to return to the grounding electrode at the SERVICE PANEL.
    Mactec54
  5. #105
    May 2016
    34
    Question Re: 110v VFD's. Any issues?
    I wanted to have a power shut-off switch right before my 240 volt receptacle so that I could unplug it safely.
    I'm pretty sure this one would work but just wanted to be sure before I order it;
    https://www.amazon.com/gp/product/B002MPPT3Y/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
    Or would I use this one, it's a Double - Pole, Single Phase version;
    https://www.amazon.com/Leviton-MS302...i&sr=1-1-fkmr0
  6. #106
    15362
    Yes you only need the double pole for your install your 240v install, at the wall a switch is nice to have but not needed if you have a disconnect at the machine
    Mactec54
Page 6 of 6 456
  1. VFD Huajiang YL600-2s-1K5 G 110v
    By mrbigde in forum Spindles / VFD
    Last Post: 12-19-2017, 04:29 AM
  2. 110v 2.2kw VFD/spindle help
    By factory5150 in forum Spindles / VFD
    Last Post: 08-10-2017, 01:16 AM
  3. 62mm 110V Spindle
    By Bob La Londe in forum Want To Buy...Need help!
    Last Post: 06-08-2016, 07:03 PM
  4. Spindle motor and VFD for 110v
    By shadowless in forum CNC Machine Related Electronics
    Last Post: 03-26-2009, 04:51 AM
  5. 110V power in
    By krymis in forum CNC Machine Related Electronics
    Last Post: 04-16-2008, 05:12 PM
