586,115 active members*
3,458 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > how to convert spindle rotation to 4th axis ?
    Sep 2005
    167
    hello
    ok, i need to install a 4th axis on my machine
    i dont want to make it as rotating axis,
    now the problem i that i want to replace the router with a much stronger and heavier one, that i do not want the whole assembly to be rotated by the stepper and hold it into position for it to work, i just dont think it will be stable enought.
    is there any mechincal idea or plans that i can use to transfer the spindle rotation to the endmill without actually moving the router itself ?
    thanks
    May 2005
    674
    There's this thing...
    http://www.5-axis.com/
    And from what I've heard in the past, it's VERY expensive. Tens of thousands of bucks USD.
    Why don't you use a rotary table 4th axis? Much less $.
  1. A axis continues rotation ?
    By thirty78 in forum G-Code Programing
    Last Post: 12-13-2006, 08:47 PM
  2. Rotation control help on A axis
    By Art Ransom in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 01:04 PM
  3. A Axis Constant Rotation
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-22-2006, 03:57 PM
  4. X axis to A rotation
    By quemast in forum G-Code Programing
    Last Post: 06-18-2006, 02:36 AM
  5. Mitsubishi Sinker Spindle Rotation
    By squarewave in forum Waterjet General Topics
    Last Post: 06-02-2006, 12:33 AM
