586,058 active members*
3,712 visitors online*
    Feb 2017
    Arduino/Uno/Grbl
    I have an E3 cnc from Bob's cnc. It was working pretty good for a newbie. Then I started a new project all went well, I
    could get it to home and jog even reset home and return to home where I had reset. All of the functions worked until I hit
    run then it did nothing just stayed in one spot. I tried some of the other gcodes that had i had ran successfully before
    and none of them would run at that time. I just gave up until a few days ago. I tried again and nothing had changed so I
    opened the firmware settings and turned off the soft limits ( changed from 1 to 0) when I tried running again everything
    seemed to work I just had to be careful with my measurements. One other thing when I get an error I have got to close the
    program down and start over. I have checked after an error message if I check the firmware settings it is blanck until I
    start the program over.
    I sure could use some help if you have any ideas.
    Jun 2016
    28
    Re: Arduino/Uno/Grbl
    You didn't mentioned which g-code sender was used. Looks like grbl goes to alarm state for some reason, so all subsequent commands are halted, alarm state could be disabled with grbl's soft reset functionality, it should be somewhere in g-code sender UI. If problem really connected with soft limits it could be wrongly set working coordinates or misplaced work origin in cam software. I reccomend to try bCNC https://github.com/vlachoudis/bCNC , it has helpful visualation and if grbl goes to alarm state software could show info about cause, just click on red alarm button.
    Its the GCODE Sender. When you hit start on the G CODE sender is send multiple commands to GRBL versus the one command you have successes with now. GRBL needs to respond to those with a 'ok' some how the sender and grbl is getting mixed up and is causing the commands to not be sent. you need to try a different sender. If you have a RPI 1 you can use our sender at https://www.readymotioncontrol.com/2...dy-motions-ui/ or use UGS at https://winder.github.io/ugs_website/
  1. Which pp to choose for arduino grbl?
    By CptanPanic in forum Post Processors
    Last Post: 03-08-2021, 11:05 PM
  2. Arduino GRBL VS LinuxCNC
    By valmar in forum DIY CNC Router Table Machines
    Last Post: 01-15-2018, 05:50 PM
  3. Arduino Mega grbl
    By cilim in forum Arduino
    Last Post: 08-10-2016, 02:12 PM
  4. arduino nano with grbl
    By mrsnowie in forum Hobby Discussion
    Last Post: 01-06-2016, 06:25 AM
  5. Should I use LinuxCNC or grbl/arduino?
    By CptanPanic in forum LinuxCNC (formerly EMC2)
    Last Post: 04-23-2012, 07:06 PM
