586,062 active members*
4,610 visitors online*
    May 2017
    Grizzly G0602 or G0752
    I am setting up a CNC Lathe and would like the community input. Since the G0752 has a 3Phase 1HP variable speed setup, will that easily interface with Mach3 and other software? Or should i just get the G0602 and upgrade the motor and add my own VFD system? Price is not a concern, its a matter of overall simplicity in integration and performance. Planning on using DMM ac servos and ball screw setup. Thanks!
    Sep 2006
    509
    Re: Grizzly G0602 or G0752
    Looks like Grizzly actually incorporated a VFD that you can use, the user manual for the VFD is 399 pages so I didn't read it all but the basic control is a 0-10V analog input which most control systems can be made to work with. It may have other advanced features but that is beyond what I'd be looking to do - the 0-10V is probably good enough. I say get the G0752 unless it may be a bit more expensive than doing it yourself but saves you trying to source the right frame motor and a VFD, plus shipping on both those parts.
    Mike
    May 2017
    I ended up getting the G0602 and upgrading to a better motor for the same cost, but now I need to get some kind of custom tool plate made for gang tool setup. My CNC setup will be the following:
    LATHE
    - G0602
    MOTOR - Leeson 1.5HP 3 Phase 3400RPM
    VFD - Hitachi NES1-0158B 2HP w/ panel update
    RAILS - Updated to Ballscrews
    SERVO - ClearPath SDSK-2321S-RLS
    PSU - ClearPath IPC-5
    ELECTRONICS
    PoKeys 57E for Ethernet Core Board
    RJ45 to ClearPath Driver
    M16 - POKEYS Motion Motherboard for Mach4
    A31 - Latch Twist-Release E-Stop Button
    Rotary Encoder
    12mm Inductive Switch
    C48 -EXT_E-Stop & probe connector board
    Tormach Probe
    MPG16 - CNC lathe control panel
    Jul 2016
    41
    Re: Grizzly G0602 or G0752 NEW MACHINE BUILD ???
    Quote Originally Posted by alphabravo View Post
    LATHE
    - G0602
    ELECTRONICS
    Rotary Encoder
    Tormach Probe
    Ummm.. so what's happening with the "build", or is there even a build ??
  1. Precision Matthews PM 10X22V vs Grizzly G0752 10X22
    By flyingdragon in forum Benchtop Machines
    Last Post: 09-16-2015, 09:51 AM
  2. Jet BD-920W vs Grizzly G0752 / G9972Z
    By 65Cobra427SC in forum Uncategorised MetalWorking Machines
    Last Post: 03-25-2015, 09:51 PM
  3. Grizzly G9972Z,G0602,or G0752 Lathe
    By Coolant Slinger in forum Benchtop Machines
    Last Post: 02-27-2015, 04:34 AM
  4. Grizzly G0602 Spindle removal
    By LJMfab in forum Benchtop Machines
    Last Post: 03-06-2014, 11:43 PM
  5. Grizzly new G0752 lathe
    By gta388 in forum Benchtop Machines
    Last Post: 08-29-2013, 12:00 AM
