586,075 active members*
4,198 visitors online*
IndustryArena Forum > CAM Software > Mastercam > anyone have MC CIMCO parameters to send to M32 Mazak control?
    Aug 2005
    124
    Hi All.
    I have an RS232 cable to my V-10 with M32 control. I can get a program from the machine back to my CIMCO editor since I have the parameters from Mazak on how to set up the commmunications.
    However when I try to send into the machine I get "553 tape reader error". Since I get code back to the PC, I think all the big parameters are OK, but of course there are all the little ones in CIMCO and the COM port that are not mentioned in the Mazak documentation.
    The CIMCO software offers the follow choices for "Flow Control"; none, software, hardware and hardware and software
    The COM port in Device Manager offers the following choices; none, Xon/Xoff and hardware.
    Screen shots of your setting screen for the CIMCO and COM port would be awesome but all data is welcome.
    Apr 2003
    3578
    Re: anyone have MC CIMCO parameters to send to M32 Mazak control?
    Did you get this working? did you call CIMCO support as there are no default parameters to give you that makes it work pacific to a MAZAK.
    Cadcam
    Aug 2005
    124
    No I didn't get it working actually yet. Mazak does have a publication that purports to lay it all out using an old RS-232 communications software. These is also service tech who is willing to work with me to get thru it. I'll keep you posted.
  1. NEED PARAMETERS FOR MAZAK VQC20/40 WITH MAZATROL CAM M2 CONTROL
    By junk101 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-25-2021, 04:42 AM
  2. Do you use Cimco DNC-Max or Editor to send to the machines
    By cadcam in forum USB, RS232, PARALLEL etc
    Last Post: 08-21-2017, 03:26 PM
  3. Can't get CIMCO/DNCMAX to send the NC file to the machines
    By dsl145 in forum DNC Problems and Solutions
    Last Post: 02-28-2015, 11:04 PM
  4. Send program from PC to Haas via RS232 with CIMCO
    By piridirk in forum Haas Mills
    Last Post: 05-27-2014, 03:10 PM
  5. M2 Control send/recieve parameters via RS-232?
    By nlh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-19-2012, 02:07 AM
