586,121 active members*
3,084 visitors online*
Thread: mach3 screen
    Mar 2016
    46
    mach3 screen
    Although this is not a huge problem, it can be annoying. I have mach3 on 2 computers. The one the runs the CNC show the image as slightly distorted, IE. a circle as an oval, with it being long on the X axis. It does produce the machined material correctly though. Just wondering why, and how to fix. thanks.
    Feb 2017
    7
    Re: mach3 screen
    I think if you check"reversed arch's in front tool post" , it gets rid of that. Config> Ports and Pins> Turn options
  1. Mach3 2010 Screen set
    By ger21 in forum Screen Layouts, Post Processors & Misc
    Last Post: 02-12-2024, 06:45 AM
  2. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  3. Mach3 Touch Screen
    By ariel6 in forum Screen Layouts, Post Processors & Misc
    Last Post: 07-28-2013, 09:15 AM
  4. mach3 display screen
    By woodman08 in forum Mach Mill
    Last Post: 08-18-2009, 05:45 PM
  5. Personalizar el screen del Mach3
    By Creisen in forum Spanish
    Last Post: 07-19-2007, 01:30 AM
