586,080 active members*
3,485 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Communications setttings for MAZAK M32 thru CIMCO editor
    Aug 2005
    124
    Hi. Anyone out there using the MasterCam's bundled CIMCO editor to send G-code programs to a Mazak M32 controller?
    I have the bits and baudrates right, but there is something wrong in the 'handshaking' settings ( hardware, software, Xon/Xoff and the like for both the COM port and the CIMCO sofware) . It sees that it is sending, but then errors out.
    Amazingly CIMCO software does not have a handout sheet of settings for CIMCO to M32 control. The Mazak-provided data does not go into "handshaking" settings either.
    If yours is working, PLEASE reply. Just by looking at a few things with you in your CIMCO I can fix my problem. rght now I'm shooting in the dark.
    Apr 2003
    3578
    Re: Communications setttings for MAZAK M32 thru CIMCO editor
    So are you able to upload or download at all? Are you connected to the RS232 port and if so were did the cable and connections come from. did you make them or are you using gender changers. these were we start.
    Cadcam
    Apr 2003
    3578
    By the way the com port is handled by your computer as the Mazak does not car as long as you are using the right comport you are plugged into the computer.
    were are you getting the error at the machine control or the computer? what is the error?
    Cadcam
    Aug 2005
    124
    Quote Originally Posted by cadcam View Post
    Sorry I should have said; I am getting about 1/3 of a program up to the PC when sent from the Mazak. No error at the control when uploading, just 2/3 of the program is lost. So I think the BIG [parameters are right (baud, stop bits, data bits), but I think the "flow control" is not set right in the CIMCO.
    When I try to send down a program from PC to M32, I get "551 tape reader error", BUT the M32 screen does change to the program number at the head of the sent program so it is seeing some of that incoming program.
    So close.......
    Sep 2007
    9
    are your %'s in the right places. Also this may be stop bit problem. If your machine requires 2 and your using 1 it will prematurely stop the process.
  1. Mazak T32-3 RS-232 communications
    By smts in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-17-2020, 07:07 PM
  2. Cimco editor can not run Back plot for simulation
    By vn023275721 in forum NCPlot G-Code editor / backplotter
    Last Post: 12-09-2017, 01:58 PM
  3. Do you use Cimco DNC-Max or Editor to send to the machines
    By cadcam in forum USB, RS232, PARALLEL etc
    Last Post: 08-21-2017, 03:26 PM
  4. Replies: 1
    Last Post: 07-09-2011, 10:57 AM
  5. CIMCO V.S. MASTERCAM OR LEGACY EDITOR
    By CNC_BOB in forum Mastercam
    Last Post: 03-12-2010, 02:07 AM
