586,061 active members*
4,564 visitors online*
Thread: Conversion
    Feb 2013
    4
    Conversion
    Hi we have 4 XYZ machines and are excellent BUT we also have a pinnacle with a Acu-Right controller the question is can you convert this to a XYZ protrack controller this making all machines the same as Acu-right is murder to use plus it only has a floppy disk drive for inputing code from Alphacam
    thanks
    Dec 2013
    5717
    Re: Conversion
    The short answer is YES. As long as the Pinnacle machine ''looks'' like the XYZ machine to the controller it should work fine. The difficulty might be in getting the Pinnacle machine to be compatible with the ProTrack controller. The most important issue would be the axis motor/drive compatibility. If they are controlled in the same way on both machines then it should be pretty easy.
    Feb 2013
    4
    Re: Conversion
    thats Great thanks i will no doubt get someone in to give us a price to do the job. its a shame because everyone shys away from it.
  1. My X3 CNC Conversion
    By cadmonkey in forum Benchtop Machines
    Last Post: 07-03-2009, 04:30 PM
  2. servo conversion vs stepper conversion
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2008, 08:54 PM
  3. CNC Conversion
    By jfh2007 in forum Australia, New Zealand Club House
    Last Post: 05-15-2008, 07:45 AM
  4. Conversion
    By gerrieg in forum Community Club House
    Last Post: 05-03-2008, 08:39 AM
  5. conversion ?
    By kenlambert in forum BobCad-Cam
    Last Post: 03-20-2005, 07:26 PM
