587,047 active members*
2,499 visitors online*
    Hacking the Auto Air Gun
    Greetings,
    Flood coolant isn't ideal for youtubers so I tried our Minimum Quantity Lubrication for the very first time last weekend - and failed.
    Today I just finished a simple hack which makes the Auto Air Gun more useful. I will test it over the next weeks and report back.
    https://www.youtube.com/watch?v=CwIfhyGbcS0
    Re: Hacking the Auto Air Gun
    Hi Piece Maker,
    Really enjoyed visiting your YouTube Channel. BTW I subscribed. It was nice to see someone else that looks beyond what is currently offered in the way of options..
    A while back I was looking at using the programming in the Minimum Oil Machining to add an air nozzle to occasionally blow out the chips in deep pockets. Basically, switch between PCOOL and Air Blast using M Codes As I didn't own or have the Minimum Oil Machining installed on my HAAS, the Haas Technicians wouldn't give me the pin outs on the plugs in the control cabinet. One of my friends here helped me with a manual system that could control the (Duration i.e. length of on time) and (Frequency i.e. how often the air blast would come on. The attached links to the videos will give you a better idea of how it all worked. I attached an air line to the PCOOL Nozzle to allow for a direct air blast to the part. I also hooked up a manual air control foot switch to use as needed.
    In my opinion, what would be the ultimate system is a ring with coolant/air nozzles all the way around the diameter of the spindle similar to the ones shown in 2:12 timeline of your video that would adjust similar to the PCOOL to accommodate different length tooling. The system could be programmed to select either air or coolant or both. The air blast part of the system could be programmed to offer blasts of air to blow out deep pockets during machining operations.
    Here are a few videos of what I did to my 2007 HAAS TM-1P. BOY! That HAAS machine you have is a REAL DREAM!!!!
    https://www.youtube.com/watch?v=Xfrhq8aCu38
    https://www.youtube.com/watch?v=IxOgYId27tw&t=21s
    https://www.youtube.com/watch?v=B1ArxUjLy5c
    https://www.youtube.com/watch?v=zssH53f_7sA
    https://www.youtube.com/watch?v=LWt0R58VTs0
    This is the older model PCOOL Unit
    https://www.youtube.com/watch?v=wT3BwMbK4oU
    Here are a could of links to threads I started here on the forum.
    http://www.cnczone.com/forums/haas-m...nt-nozzle.html
    http://www.cnczone.com/forums/haas-m...-machines.html
    Older model PCOOL unit repair
    http://www.cnczone.com/forums/haas-m...cool-help.html
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
  1. Hacking a CNC machine, but which one ?
    By julien38190 in forum Benchtop Machines
    Last Post: 05-06-2016, 09:30 PM
  2. keyboard hacking
    By dertsap in forum CNC Machine Related Electronics
    Last Post: 12-08-2009, 04:11 PM
  3. MPG's, Hacking or Roll y'er own or?
    By JerryFlyGuy in forum CNC Machine Related Electronics
    Last Post: 01-26-2007, 05:01 PM
  4. Hacking up a bad controller
    By originator in forum CNC Machine Related Electronics
    Last Post: 10-08-2006, 02:14 AM
