586,103 active members*
3,748 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi TS15 Turret reset procedure
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Quote Originally Posted by docdesigns View Post
    Hi All,
    * I have 1998 Hitachi Seiki TS15 with seicos sigma 21 control.* I recently had the timing belt in the turret start to fray and the belting was pulled from within the middle of the belt wrapping around the pulleys causing it to not index correctly and causing a turret index time out alarm.* I was able to clear the belting and get it working again without removing the whole turret disc and was able to continue using it while I waited for a new belt to come until it happened again for the same reason.* I removed the "tool turret disc"* and get the old belt off and replace it with a new belt.* However, the timing is now off when I index the turret so it wont clamp correctly.* I still have it apart.*
    I cannot find the correct procedure to reset the timing of the turret in my manuals.* Online it seems different models of hitachi seikis use different 3 button combinations and procedures to reset this.* I have seen that I may need to change the 1815 parameter possibly and something else K00.3?
    Does any one know the correct procedure on this lathe?* Any help would be greatly appreciated.
    Thank you
    Would anyone send the procedure
    Sting
  2. #22
    Dec 2009
    539
    Re: Hitachi TS15 Turret reset procedure
    Quote Originally Posted by sting007 View Post
    Sting
    PM me your email and I’ll send it
    John
  3. #23
    Hi John, Hope you're available.
    I have hitachi Seiko lathe ts15, 1998 model, having turret problems, it stops while indexing in anticlock direction otherwise working fine.
    Can you help.
    Thanks.
    - - - Updated - - -
    Can you help.
    Thanks.
    - - - Updated - - -
    Can you help.
    Thanks.
  4. #24
    Dec 2009
    539
    Hello
    Send me a PM with your e-mail and I’ll assist
    John
  5. #25
    Dec 2009
    539
    Hello!
    do you still need help on this
Page 2 of 2 12
  1. TS15 Turret Index Error After Power Cycle
    By alphaprecision in forum Hitachi Seikis
    Last Post: 02-02-2019, 11:37 AM
  2. Hitachi TS15 canned cycle alarm
    By docdesigns in forum Hitachi Seikis
    Last Post: 03-15-2017, 02:45 PM
  3. Tapping on a Hitachi Seiki TS15
    Last Post: 11-30-2016, 12:26 PM
  4. rROBOFIL 330F Reset procedure
    By shahrzad in forum CNC Machine Related Electronics
    Last Post: 10-16-2014, 11:25 AM
  5. Replies: 5
    Last Post: 09-13-2013, 05:03 PM
