586,207 active members*
4,136 visitors online*
    Apr 2017
    41
    bit not touching material
    using cnc shark hd3 with cut2d. first time using a cnc so i'm not sure if i'm doing this correctly. posting this here because the cut2d forum is dead and i'm not sure this is a software-specific issue?
    material is 1/4" acrylic so i set the material to .250 and cut depth to .253 so i can cut all the way through. i create my design, load it into the next wave software, set the "home" using their touch plate, start the job and the machine will trace out my design but the bit stays about 1" above the material and doesn't touch it.
    not sure if this will help, but here's the top part of the gcode:
    Code:
    ( test_250 )
    ( File created: Sunday August 27 2017 - 10:44 AM)
    ( for CNC Shark from Vectric )
    ( Material Size)
    ( X= 3.500, Y= 3.500, Z= 0.253)
    ( Z Origin for Material  = Material Surface)
    ( XY Origin for Material = Top Left Corner)
    (      XY Origin Position  = X:0.000, Y:0.000)
    ( Home Position)
    (  X =  X0.0000 Y =  Y0.0000 Z =  Z0.1010)
    ( Safe Z = 0.100)
    Nov 2015
    22
    Re: bit not touching material
    only a guess cause I'm new at this too
    but if your zeroing on top of the acrylic your cutting on the z plane needs to be a negative number
    Jun 2010
    4256
    Z must go negative as Mikey said.
    Cheers
    Roger
  1. touching off ..
    By RobSm in forum News Announcements
    Last Post: 05-15-2016, 10:14 AM
  2. G31 not stoppiing when touching
    By shags72 in forum Okuma
    Last Post: 08-14-2013, 08:01 PM
  3. Touching off Tooling
    By Jdmmk3 in forum CNC Tooling
    Last Post: 12-18-2012, 01:06 AM
  4. Touching tools off of workpiece on SL-20
    By vegas705 in forum Haas Lathes
    Last Post: 09-23-2009, 02:14 AM
  5. Touching-off
    By bloefeld in forum Haas Mills
    Last Post: 08-03-2008, 11:07 AM
