Originally Posted by
1Jumper10
Gerry,
I'm using relay 1 so I have a wire from SafetyOVR to NO1, and from CM to 0V.
And I have the Output Trigger mapped to LED 25, and set to Port 1, Pin 1.
I Initially tried mapping it to LED 27 but it behaved exactly like you described. Using LED 25 works pretty well except that it clears the E-stop condition very quickly. Watching the diagnostics page when a limit is hit or the Reset software button is pressed, the E-stop LED illuminates for ~ 1/2 second then clears. I tried looking for a more suitable LED to use but found none. I was thinking about a HotKey that would latch Relay1 but couldnt quite figure it out. I still get the interlocking feature of the OSSD with this method and it's easy to recover from Reset. But it sounds like a macroloop - custom LED is probably the better solution. However, I dont know how to write a MAcroLoop. Concerning HotKeys, if I made a custom LED and assigned a HotKey to trigger it, and then assigned an output trigger to that custom LED to close Relay 1, would that work?
