586,121 active members*
3,766 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > My HAAS VF2 is making a grinding noise during a tool change.
    Aug 2017
    My HAAS VF2 is making a grinding noise during a tool change. I made a video of it. You can hear it during the second tool change. Its like a grinding squeak when the drawbar pull up the tool holder. It will also pause in the middle of a tool change and take 2-3 seconds till it pulls up the drawbar and pulls out the tool carrier. I have searched for this but I am only finding threads on the tool holder popping out of the spindle. Any help would be appreciated.
    Feb 2010
    1184
    Re: My HAAS VF2 is making a grinding noise during a tool change.
    Quote Originally Posted by TDCMGF View Post
    I am not really hearing a grinding sound, but I hear a sound similar to when the exhaust for the tool release solenoid has been removed.
    I would suggest removing the head covers to get a better look at what is going on and where.
    Report back what you find.
    Good luck!
    Aug 2004
    780
    So did the tool pull-up time slow down markedly to 2-3 secs ?
    There is;
    less air-power, or
    more friction,
    problems in one or more mechanisms.
    Air-leaks ? Is there good pressure and volume on air ? Are You sure ? .. why ?
    If it takes 3 secs to pull up a tool, this sounds extremely slow.
    Maybe, the belleville springs are shot.
    This is common, and all spindles will need springs at some point. Cheap.
    200-300k toolchanges.
    Buy the whole drawbar assy, 300$ or so. Do not try to mickey mouse it.
    It must be either the drawing/pulling system, the drawbar, or a catastrophic spindle/tool taper error.
    Or air pressure/volume.
    It was somewhat common for drawbar assys to fail in the bellevilles- usually via time and lots of toolchange use (like upto 3 million !!! ??).
    I could see some spring parts falling inside, and creating the noise/drag.
    As I said, please *do not* try to mickey mouse with it - vs a cheap 3-500$ total haas retail assy.
    Buy the whole new drawbar set with springs. Imo.
    Apr 2019
    I am having the same issue with my Mini Mill. Did you ever find the problem/solution?
    Thanks.
  1. Replies: 7
    Last Post: 08-14-2020, 02:13 PM
  2. Buying a DMU-50. Tool change noise?
    By WallaceLau in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-13-2017, 02:20 AM
  3. Haas TM 2P making noise in the Z axis
    By sbrackett in forum Haas Mills
    Last Post: 06-29-2016, 07:55 PM
  4. Spindle making grinding/humming noise
    By machinisto in forum Haas Mills
    Last Post: 10-21-2014, 09:05 PM
