586,036 active members*
3,565 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Anyone considering the centroid Acorn instead of path pilot?
Page 6 of 6 456
Results 101 to 108 of 108
  1. #101
    Hallo UpNorth
    Do you have any photos and/or schematics of your final panel? Best would be a BOM, but that is asking a lot..
    I am looking to use an Acorn in a machine build and am hoping to learn from you to avoid making too many beginner meistakes.
    Cheers!
  2. #102
    Nov 2013
    152
    Re: Anyone considering the centroid Acorn instead of path pilot?
    Quote Originally Posted by upnorth View Post
    It now has probe protection and it works. Instead of the switch idea like it shows in the manual I used a 1/4" phono jack that closes an input when the jack is inserted. This eliminates any worries about forgetting to activate a probe protection circuit switch. I don't know if this is normal for a phono jack it came from my junk box. It could probably be wired up the same way using a stereo jack that one terminal is jumpered internally. Its probably out of some piece of commercial equipment. I am very happy with the drewtronics probe. It sure beats edge finders and gauge blocks.
    I have an output switching common to an input assigned as ProbeDetect. In my M6 (tool change) macro I have the following line:
    Code:
    IF [#4120 == 99] THEN M67 ELSE M87 ;If tool is tool 99, then activate output 7, otherwise deactivate output 7.
    This assumes that OUT7 is defined as "output7" using the Acorn Wizard for the M67 and M87 macros to work.
    I just added this line just before the end of my m6 macro. My wireless probe is tool 99. In my probe installation I added this little junction box on my spindle. It gives me a way to enable probe detect manually. It now has the added benefit of a visual indicator when the ProbeDetect input is on, such as when #4120 == 99. Very cool to have this working. This is an automatic probe detect of sorts for a situation like mine with a wireless probe.
  3. #103
    Jul 2011
    400
    I missed this question when you posted it. I used the schematics that were on the centroid website. The only thing I had to figure out was the power drawbar. Its all set up and working now. I'm on the road now I work away from home in the winter but I can post photos when I get home in the spring. I would not hesitate to use the acorn again. It works well and has never done anything weird. I would not go back to Mach 3 and will be ordering 2 more acorns to convert 2 other machines I have.
    This post was in response to thomasdahl post 101. I forgot to quote it.
  4. #104
    Jul 2011
    400
    I like the visual confirmation of the probe being plugged in. Are you using an automatic tool changer? I change mine manually.
  5. #105
    Nov 2013
    152
    I like it, too. I do not have an ATC at this time. Plan is the S30 spindle when budget and time allow. I do use an M6 T99 when using the probe to activate the ProbeDetect as described above.
  6. #106
    Jul 2011
    400
    Quote Originally Posted by slodat View Post
    I had to google the S30 spindle to see what it was. Are you seriously going to do that? If so please make a thread about it. Looks like quite an upgrade. Should be great for aluminum I wonder how it will be at lower RPM's for cutting steel. The extra HP should be nice too.
  7. #107
    Nov 2013
    152
    This would be for my 5' x 8' CNC router, not a Novakon. No steel in my case.
  8. #108
    Feb 2012
    149
    Agreed, it will have very little torque below 6-8k.
Page 6 of 6 456
  1. Centroid Acorn now available and is the real deal.
    By DICKEYBIRD in forum Benchtop Machines
    Last Post: 07-17-2018, 07:17 PM
  2. New DIY CNC 4 axis Acorn motion controller by Centroid
    By cnckeith in forum News Announcements
    Last Post: 08-23-2017, 06:20 PM
  3. Does Path Pilot support G64?
    By popspipes in forum Tormach PathPilot™
    Last Post: 04-01-2017, 03:17 AM
  4. Got my Path Pilot
    By BIG IGG in forum Tormach PathPilot™
    Last Post: 02-10-2016, 03:06 PM
  5. Path Pilot vs Mach 3
    By Bob La Londe in forum Tormach Personal CNC Mill
    Last Post: 10-12-2015, 07:55 PM
