Originally Posted by
mactec54
That is a Bearing noise, the Bearing cage is skidding which is not a good sign, when you said the noise started at around 283 RPM, If you have your spindle running at those low RPM it will over heat, and the grease in the bearings will run out, hence the noise you hear is from the Bearing having very little lube left in them
The minimum RPM for these spindles is 6,000 RPM, so in your VFD the minimum RPM Parameter Setting would be set at 100, so let hope you have not been running the spindle below the minimum RPM
For the RPM problem that takes a bit of playing with in Mach 3 mostly, that is not an unusual problem and is no real concern, and has nothing to do with your spindle noise
