586,071 active members*
4,146 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Insert stock from CAD model
    Aug 2017
    On the process that I am working on, the program begins with a half finished part in the subspindle (which works better for looping purposes). I created a CAD model of the half finished part and I'm attempting to insert it into the sequence.
    When attempting to do this, it doesn't recognize it as stock and it does not work correctly in the simulation. I also cannot move the model, it gets placed at the main spindle datum and the only way to move it is to translate the body in the setup tab, which is difficult to do accurately.
    Does anyone have any suggestions?
    Oct 2003
    127
    Re: Insert stock from CAD model
    when you insert the stl add some wire to the same layer from the base model for something of reference to use when you move the stl to the new position.
    the stl will come in exactly where the model is when you cut it so the wire will be where it really is for both.
    Oct 2003
    127
    why is there a link tied to the words "the wire" in that post i just made???
    talk about click bait, WTF??
  1. Savage model 93 stock.
    By JasonCcnc in forum Gunsmithing
    Last Post: 05-20-2019, 02:23 AM
  2. Replies: 3
    Last Post: 06-17-2016, 04:55 PM
  3. Stock model
    By Gregore in forum MadCAM
    Last Post: 05-28-2013, 12:37 AM
  4. X5 stock model
    By jjacoby in forum Mastercam
    Last Post: 01-21-2011, 02:12 AM
  5. 3d stock model
    By camtd in forum EdgeCam
    Last Post: 10-20-2006, 05:36 AM
