586,103 active members*
3,959 visitors online*
Page 1 of 2 12
Results 1 to 20 of 35
    Mar 2017
    250
    Mach 2010 screenset, anyone using?
    Has anyone modified the 2010 screenset to work with the new corner finding touch plate from crp? I'm using aspire and want to use the tool change postprocessor because loading multiple sections of gcode is time consuming.
    I would like to be able to have a mounted plate for tool change touch off and use the crp one for the surface of the part. I also want to be able to use the crp auto probe functions for corner finding still. Is it possible to use both?
    I may try to hack this together, but would like input before screwing things up. Which I'm probably bound to do a few times.
    Sent from my SM-N920V using Tapatalk
    35538
    Re: Mach 2010 screenset, anyone using?
    You can find the corner with the 2010 Probing wizard, then use the standard auto zero macros.
    Mar 2017
    250
    Gerry, thanks for the reply! I haven't tried to implement your screen set yet, didn't know if i needed to do anything special.
    But since you saw this, i might as well ask the creator a question. I read that with the stationary plate, it can be whatever thickness and still calculates the correct z height. How does the original machine z zero get set? Is it when i run the zero z using my moveable plate? Otherwise, it seems like the mounted plate would need a measurement entered to correct.
    I do not know if you're familiar with cnc router parts new touch plate, and I haven't run your screens yet, but does the corner wizard allow me to choose the measurements for x max/min y max/min to correctly position the bit?
    Thanks in advance, I'm new to all of this and really appreciate the help of the community. Hopefully I can give back one day. Or, at the least, my questions will be found for others to learn as well.
    35538
    The manual for that touch plate doesn't explain how it's used but I'm assuming it basically finds the center of the pocket inside it? Similar to the Triple Edge Finder? If so, you just jog the bit down inside the pocket, and the pocket center finding macro will find the center, which is the corner.
    There are two auto zero macros. A simple one, just for setting Z zero one time.
    Then there's an Initial Auto Zero, which is used with the fixed plate. It first sets Z zero, using your CNCRP touch plate, then goes to the fixed plate and saves it's location.
    So if you are just doing a simple job with one tool, you can use the simple auto zero, which is faster. If you will be doing tool changes, you use the Initial Auto Zero, which sets up the fixed plate for tool changes.
    Mar 2017
    250
    Awesome! Thanks for clarification. I'll try everything tonight. Can't wait!
    Jul 2017
    42
    I just got the 2010 screencast for basically the same reason. For the mounted plate, how do you handle connecting the ground? Is there a place that we can connect the ground so we do not have to keep connecting it to the spindle?
    Jul 2015
    33
    I haven't installed it yet, but I purchased an ~8" hose clamp and plan on running a 14 ga ground wire from my spindle to the ground sensor on my touchplate through the ecage. Will strip the wire and clamp it to the spindle.
    Jul 2017
    42
    If anyone is interested I wanted to mention that I got the 2010 Screen Set and Multi Tool Probing working very well with my PRO4824. I built a WYW ( Y ) of M12 connectors and ran a wire up to the spindle connected to the mount.
    I'm still working on the more automatic probing ( X and Y at the same time ) but easily got X and then Y to probe.
    So far pretty happy with 2010.
    Mar 2017
    250
    Quote Originally Posted by PapaLima View Post
    I haven't had time to try anything. Mind sharing your config? I have the 4896, but you're the only post I've seen for the crp machine specifically. It would be great to have too changing working instead of loading each program every tool.
    Sent from my SM-N950U using Tapatalk
    Jul 2017
    42
    Quote Originally Posted by ubergeekseven View Post
    I'm not using any custom or special configs. I had everything working with plain Mach3, bought 2010, and followed the install instructions carefully.
    I would recommend setting up a new profile so you don't overwrite macros that you might want later.
    And always make a backup of your mach directory. ;-)
    The automated changing tools is really nice for sure!! Next step is a full ATC but I haven't found a good inexpensive one.
    Mar 2017
    250
    One thing I was worried about was the z offset that comes with the crp config. Did you have to change that, or did the offset not do anything to impact the macros for the 2010 screenset?
    Jul 2017
    42
    I didn't change that. The 2010 is basically a different "look" to Mach3 and some different Macros. All the settings stay the same ( except a couple for Z axis ). There were a lot of times where I flipped back from 2010 to the normal and back again.
    Sep 2017
    78
    Please tell me if I need to start a new thread for this, but it's related so maybe there will be some common interest. I'm helping a friend get his new FLA Saturn 2 up and running with CNCRP NEMA 34 P&P setup, running Mach3. The final parts should be here Monday to connect the motors to the R&P drives. I bought the 2010 screenset and will install it once we've tweaked everything and know that the router is functioning the way we want.
    My question is this - since 2010 supports both a single touch-off and a secondary, has anyone modified it to use the second touch-off for a maximum depth setting? I've had this feature on other machines and it is worth its weight in gold. Take the first reading from the top surface and the second from the spoilboard. The second setting, Max depth, limits the depth of cut to that reading regardless of what the program tells it to do. As a bonus, the Max depth can be adjusted either up or down in .001" increments for cutting down to, but not through the backing material on acrylic, etc.
    If 2010 or Mach3 does not have the capability, does anyone know of a system that would work with CNCRP?
    Mar 2017
    250
    Quote Originally Posted by micknm View Post
    That sounds awesome. I would love that ability as well. I'm so inexperienced with CNC that when I went to do the setup, I basically got overwhelmed with my lack of knowledge, that I walked away a couple months ago and dealt with the tool change inconvenience.
    Jul 2017
    42
    I hear your frustration. I felt that way a bit at the beginning but once I got into it, and took my time, it wasn't that bad. If you use a new profile you can always go back and use your machine while you play around with 2010. I read through the instructions a few times and then walked through it to do it.
    Actually the hardest part, which actually wasn't that bad, was getting the wiring worked out because I wanted to use plugs to keep it clean.
    35538
    My machine has a z offset of 8 inches and the 2010 is 0
    What Z offset are you guys referring to?
    35538
    Are you sure their Z axis home position is at 8 inches? That doesn't make any sense.
    When you are moving the Z axis down, does the Z DRO count down? It should, as that's how 99.9% of people's Z axis work. So you shouldn't need to change the Z direction.
    Z Home being zero (top of travel) is the most common, which is why the 2010 macros require it. To prevent the macros from crashing the machine into the top of the travel, it requires the Z Home position to be 0.
    IF you go to Config > Home/Limits, Is there a value in the Z Home Offset? If what you are saying is correct, it should be set to 8 there.
    Mar 2017
    250
    I figured this was weird since no-one else on the internet mentions this. I am surprised that the poster who has the cncrp machien and replied to this thread, got it working without throwing something off somewhere. It is set to that.
    35538
    All you need to do is change the soft min to -8, soft max to 0, and home offset to 0. Then it should work fine with the 2010 Screenset macros.
    Not sure if CNCRP supplies any macros that require those specific Z axis settings.
    Mar 2017
    250
    Thanks. I'll send them that question to see if they do. The only macro they have, that I'm aware of, is their touch plate macro attached to the hidden script that executes when pressing the 1024 screen set auto tool zero button. M6 start and end are the default. I'm not sure what the code for ref all is, maybe used with it too.
Page 1 of 2 12
  1. 2010 screenset
    By Splinterdone in forum Mach Wizards, Macros, & Addons
    Last Post: 04-13-2018, 03:29 PM
  2. Screenset 2010
    By cubalu in forum Mach Wizards, Macros, & Addons
    Last Post: 06-12-2014, 11:40 AM
  3. Besoin d'aide Screenset 2010
    By cubalu in forum French
    Last Post: 06-05-2014, 11:44 AM
  4. How do I wire a touch plate for the 2010 Screenset?
    By offthewall in forum Screen Layouts, Post Processors & Misc
    Last Post: 02-03-2014, 05:38 AM
  5. 2010 Screenset error confusing me....
    By racedirector in forum Mach Software (ArtSoft software)
    Last Post: 05-25-2012, 04:47 PM
