586,051 active members*
3,983 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > CNC GCode not following correct path
    Nov 2013
    Unhappy CNC GCode not following correct path
    Hello everyone,
    Im stucked here without knowing how should I fix this error. I just built my Foam cutter CNC, I ran several small cuts in prior to test and calibrate machine, they came out pretty well, was really excited. But when I ran into a big sheet of polyestyrene, it came out in a really weird and unpleasing curves (you can see it in attached pictures).
    The software I am using is CorelDraw (SVG Export) -> DOCADO PathEdit to generate GCode -> Mach3 as the TB6560 controller.
    The only change I did to GCode, was to set a new start/origin in LazyCam and entered a new speed for the tool.
    Does anyone have any kind of idea what might be causing this?
    Thanks in advance!
    Nov 2013
    Re: CNC GCode not following correct path
    After a lot of research, I found out about the continuous mode of mach3, and learned the hard way about it. If anyone do get through this error after building the machine, I will leave the tip for solution I had to do: Just tune the motors acceleration to a higher one, so it will allow mach3 to work with CV. If you cant work out with a higher acceleration, disable the CV mode.
  1. Replies: 41
    Last Post: 07-02-2016, 09:02 AM
  2. DeskProto 2D Operation - Not Sure Tool Path is Correct
    By GregGleason in forum Uncategorised CAM Discussion
    Last Post: 04-22-2014, 12:07 PM
  3. Mill jumping but LinuxCNC shows correct path
    By thegrandwazoo in forum LinuxCNC (formerly EMC2)
    Last Post: 01-11-2013, 06:25 PM
  4. correct gcode ?
    By jezx in forum Canadian Club House
    Last Post: 02-17-2011, 03:17 AM
  5. Torchmate not following correct path
    By MoparJon in forum Torchmate
    Last Post: 09-09-2008, 07:35 AM
