586,110 active members*
3,343 visitors online*
Results 1 to 5 of 5
    Sep 2017
    5
    proma THC SD with a chinese TB6560 board
    Hello,
    I am trying to get the proma THC SD to work with a cheap chinese 3 axis TB 6560 board (yes I know )
    Actually I ordered a proma THC but got the SD version.
    Now since I don´t get any feedback from proma I´ll try my best here:
    Can I wire this directly from the LPT?
    As in this description it connects from a CNC Board to a Z-Motor driver. This doesn´t make much sense to me as the CNC board would be the Z-driver already ?
    So can I use the Step/Dir pins from the LPT to connect to the proma and go the driver board then ?
    Like: LPT -> proma -> TB6560 -> Motor ?
    thanks
    noobody
    Jul 2005
    2415
    Re: proma THC SD with a chinese TB6560 board
    It's because you got the wrong model if you want the software to move the Z for THC, I have no idea how the SD lets the control software know its moved Z instead of the software. With no bidirectional communication to the software it operates as a quasi-stand alone THC but it still relies on the software to do things like touch -off , raise to rapid height , Torch on , etc. I gather your goal is to do this build on an absolute shoestring. The good thing is you are getting a free eduction about things that either won't work or will take a lot of time to get a marginal result.
    Sep 2017
    5
    Hmm true, unless the proma would act bidirectional here.
    Jun 2018
    Hi i have the same setup im trying to get hooked up. I'm unsure of which pins to use or hook up the proma the for on my tb6560 board. Where u able to get it working
    Sep 2017
    5
    I haven´t made any progress on the machine for quite a time due to lack of time, however I exchanged the proma to the older non-SD version and I believe the setup with that isn´t too difficult.
    I mounted it to the converter and wired it to +/- of the converter so far. The control wires should go to the end / home switch connector of the TB6560 if I am right, (the Proma diagram doesn´t make much sense to me).
    The rest is set up in mach3 then.
  1. Short Circuit on a chinese TB6560 Board
    By Tommhy in forum Stepper Motors / Drives
    Last Post: 04-21-2015, 11:56 PM
  2. ...chinese TB6560 board snubbers
    By Martel in forum Stepper Motors / Drives
    Last Post: 04-11-2015, 08:53 PM
  3. Chinese TB6560 driver green board
    By georgei in forum Stepper Motors / Drives
    Last Post: 12-24-2014, 08:45 PM
  4. proma thc conection to logitrol board
    By ciccio15 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-29-2014, 11:03 AM
  5. New (red version) of TB6560 chinese driver board
    By hspalm in forum Stepper Motors / Drives
    Last Post: 02-23-2014, 01:34 AM
