586,275 active members*
3,238 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Can't figure out my mistake - Another homing question with Mach3
    Nov 2005
    34
    I'm ready to kick myself when I find out how simple the solution is, but for now, I'm hitting a brick wall.
    I'm trying to get homing working with KFlop and Mach3. My homing routine works perfectly with KMotionCNC. However, nothing is happening with Mach3.
    In an effort to simplify debugging, I have reverted to using the unaltered sample program "HomeMach3.c". When running under KMotionCNC, the appropriate messages appear in the KMotion Console window. When running under MACH3, nothing!!
    I've checked and double checked the configuration of the Dynomotion plug-in in MACH3. The program path for the homing program is correct. I'm using thread 3 and data 5, (the same as used in KMotionCNC).
    I have the limit switches set to Port #1, Pins 1 and 7 (For the X and Z switches). Using the Mach3 diagnostics screen I have verified the operation of the limit switches.I have used a Mach3 screen editor to test both OEM Codes 22 and 24 as well as 1022 and 1024 (X and Z axis).
    What am I missing?
    May 2006
    4045
    Re: Can't figure out my mistake - Another homing question with Mach3
    Did you read this note?
    Note: if Homing Inputs are enabled in Mach3 | Config | Ports and Pins | Input Signals | X Home, Y Home, Z Home, A Home, B Home, C Home then Mach 3 will NOT call the Plugin to do Homing. Please make sure these Inputs are NOT enabled.
    HTH
    Regards
    TK
    http://dynomotion.com
  1. Mach3 Homing Step Off
    By tjb1187 in forum Mach Software (ArtSoft software)
    Last Post: 09-29-2016, 02:41 AM
  2. [Galil DMC 1820] I can't figure out how to operate with Mach3.
    By LambdaCNC in forum Mach Software (ArtSoft software)
    Last Post: 06-18-2016, 05:16 PM
  3. Mach3/Kflop - Homing
    By Snipes44 in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-18-2012, 06:06 AM
  4. Homing Mach3
    By omboli in forum Mach Software (ArtSoft software)
    Last Post: 08-10-2012, 12:30 PM
  5. Mach3 - Homing Problems
    By rc123456 in forum Mach Software (ArtSoft software)
    Last Post: 02-19-2010, 02:58 PM
