586,058 active members*
4,736 visitors online*
    Dec 2011
    18
    Question Laser controller for existing machine
    Hi! I built a DIY CNC machine that I use for laser cutting/engraving.
    Until now I did simple jobs so my controller was fine.
    Today I'm interested in raster engraving, hence I'm looking for a controller that allows spindle changes on-the-fly. As you know the laser power is usually set by the PWM output, bound to the S command. But common cnc controller will stop the movements when such a command is found and this should be avoided.
    Right now I have a TinyG controller. Looking at its github repository the project seems almost dead (no commits since two years!). Anyway I found a forked firmware that reduced a lot this issues but doesn't fix it completely.
    Another common controller is GRBL for Arduino: it's not updated since a long time too but it was designed with the "laser mode" feature that is exactly what I'm looking for.
    Before buy an Arduino board and a suitable shield, I wonder if it's a good choice or there are something else better for this kind of job. My budget is limited to few hundred dollars but perhaps there's something better than an 8-bit MCU :-)
    Sep 2005
    1740
    Re: Laser controller for existing machine
    Do you have standard stepper motors and drives? If so I would highly suggest spending $300 or so and putting in a DSP controller. I built a machine and used GRBL and the like, it was never worth more than just a toy to play with. You can buy new ones at LightObject dot com and they come with some pretty decent software that will let you do everything you want. BTW this is not a K40 machine is it?
    Dec 2011
    18
    Quote Originally Posted by wmgeorge View Post
    Yes, I have standard stepper motors. Right now, using TinyG, I haven't standard drivers (because TinyG has them built-in) but I have some spares around.
    Interesting to know...
    Weird, I get error 403 (Access denied) when visiting that website.
    No, it's not a K40 machine. It was based upon LitePlacer that I have modified to host a 6W 445 nm laser module.
    Sep 2005
    1740
    Laser cutter and engraving machine metal wood. Sacramento CA works fine for me. Yes my DIY laser project was a 5 watt blue light laser, had over $500 invested. Got tired of messing with it and sold the whole works for $150 (I think) and purchased a real co2 machine I could so something with. I also have a 20 watt fiber laser.
  1. Laser engraving machine not firing laser from software or controller.
    By JustTruckinng in forum Engraving Machines
    Last Post: 05-14-2014, 04:14 AM
  2. moving existing part programs to new machine
    By Joesph Jackman in forum Mastercam
    Last Post: 04-18-2012, 07:07 AM
  3. Using an existing cnc machine for 3d printing
    By dmauch in forum 3D Printer / 3D Scanner Discussion
    Last Post: 02-21-2012, 04:50 PM
  4. Revamp Existing Machine
    By NetStorm in forum CNC Wire Foam Cutter Machines
    Last Post: 08-04-2011, 08:11 PM
  5. Laser Addition for existing CNC - Possible ?
    By Geetar-ist in forum Want To Buy...Need help!
    Last Post: 01-12-2009, 09:50 PM
