586,094 active members*
4,137 visitors online*
    Aug 2016
    32
    Solid CAM and LinuxCNC
    I've been using Inventor HSM for my CAM activities and it's possible to post process the information to a format which is compatible with a generic Linux CNC machine.
    In Solid CAM this generic set up doesn't seem to be available as all that is listed are about ten specific machines. Does anyone know which of these will work with Linux CNC or if not how can i get the output code to be Linux compatible.
    Apr 2004
    5737
    Re: Solid CAM and LinuxCNC
    Try using a Fanuc post-processor; Linux CNC mostly adheres to the Fanuc standard. Particular G-code functions might act funny, but you should be able to customize the post to work around the problems.
    Andrew Werby
    Website
    Aug 2016
    32
    Thanks. I'd read somewhere else that the Fanuc post-processor should be ok. I guess it just wouldn't run if it found some inconsistencies.
    From what you say there isn't a generic post processor that could be loaded into Solid CAM.
    With the exception of this issue Solid CAM does seem to be better than HSM.
  1. LinuxCNC 2.7.1
    By kstrauss in forum Tormach PathPilot™
    Last Post: 10-18-2015, 08:21 PM
  2. negative of a solid in solid works
    By ringanator in forum Solidworks
    Last Post: 02-09-2015, 03:58 PM
  3. Linuxcnc 2.6.0 is out.
    By samco in forum LinuxCNC (formerly EMC2)
    Last Post: 07-30-2014, 03:13 PM
  4. Problem Subtracting Solid from solid Ver25
    By Kencor1 in forum BobCad-Cam
    Last Post: 02-21-2014, 04:15 AM
  5. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
