586,082 active members*
3,613 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Visual mill -Keep material for work holding when 3D profiling
    Aug 2005
    20
    I have a solid model of a hammer handle that I am trying to machine out. I have it in Visual mill. I have extended each end of the handle out by 1" but of a smaller dia (ellipse shape). The handle is 12" long and is 14" with the extra material on each end. .I made my material 13" long and centered. The block I start with is 16" long. I profile one side (I machine to a depth of half my Z thickness plus half the radius of the b all mill) then flip and profile the other side. My thought was it would not cut the material al each end because the solid model extends out past the stock material. What happens is it cut to depth on the ends so when I flip it and it roughs out the shape all the way to depth there is no material on the ends left to hold the part to complete the final finish passes.
    So my question if how to I make Visualmill not machine on the ends of my part? I know how to do this when doing 2D work. You get a option to leave tabs. That does not show up as a option when doing 3D surface profiling.
    Scott
    Aug 2005
    20
    Re: Visual mill -Keep material for work holding when 3D profiling
    I think I have it figured out. The simulation looks correct, just need to make some chips tonight to verify.
    What I had was a "horizontal finishing" cut operation first then a "parallel finishing" operation second to clean the part up. The issue was with the "horizontal finishing" cut operation. I switched both cut operations to parallel and it left the ends alone. I leave .060 of material with the first cut and then 0.0 on the second to clean it up fully.
    For some reason, the "horizontal finishing" cut operation always machines the ends of the part. "Horizontal roughing" does the same thing also so it doesnt matter if I call out the roughing vs finishing cuts. It is the horizontal vs the parallel cut that makes the difference.
    Scott
  1. Visual Cam 1.0/visual mill 6.0 5 axis?
    By Swets in forum Visual Mill
    Last Post: 03-05-2017, 10:32 PM
  2. Replies: 3
    Last Post: 05-14-2014, 01:42 AM
  3. Holding down material
    By cncmadness in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-16-2013, 12:21 PM
  4. Work holding options to hold thin round work? .024, .046 etc
    By KyleH2 in forum MetalWork Discussion
    Last Post: 06-07-2010, 07:22 PM
  5. Holding down material
    By swoolhead in forum DIY CNC Router Table Machines
    Last Post: 10-04-2005, 09:48 PM
