586,060 active members*
4,127 visitors online*
    Apr 2015
    77
    Spindle type, EMD motor
    Hi all,
    I've just started investigating and sorting out an old (1990) benchtop mill.
    I'm wondering if the pictures attached could make anyone tell what kind of tool holder that will fit. Any hints appreciated.
    Thanks in advance.
    The serrated sleeve is spring loaded and can be pulled downwards - to release a tool holder, I'm just wild guessing
    The taper opening measure about 17mm.
    Regards.
    Apr 2015
    77
    Re: Spindle type, EMD motor
    ... and here is a full pic of the chap.
  1. CNC Spindle motor power wire type and sheilding from other wires?
    By PIVOTALCUSTOMS in forum Uncategorised MetalWorking Machines
    Last Post: 04-25-2014, 02:50 PM
  2. Need help determining what type of spindle+motor I need.
    By sburck in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2012, 11:35 PM
  3. Replacing Spindle Motor on Prototrak type mill
    By mgb1974 in forum Uncategorised MetalWorking Machines
    Last Post: 07-02-2008, 12:29 PM
