586,602 active members*
3,471 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Anyone kill a G203V yet?
Page 3 of 8 12345
Results 41 to 60 of 149
  1. #41
    Apr 2007
    1955
    Thank you. I have been reading the various Gecko drivers specs, and just read through the pasted wiring diagrams section. With all of the protections on this driver board (203v), it looks like a break out board is no longer needed ? or is that only if you have the G Rex 100 ?
  2. #42
    A breakout board is a convenience that shouldn't be overlooked. It beats the daylights out of the alternative; wiring directly from a parallel port. Otherwise a G203V is perfectly happy running from a directly wired parallel port or from any other step/direction source so long as the step/dir signals are between 2.5V to 5V in amplitude.
    Mariss
  3. #43
    2010
    Hey Mariss,
    My curiosity is getting the best of me. I sent a 203v back to you that was acting strange, told you I would be out of town and to hold the drive.
    Still out of town but have access to e-mail and this site. Any news on the drive yet?
    Even when I can't play I'm thinking about it!
    thanks,
    jb
  4. #44
    jb,
    Under what name or company name was it returned? That is the only way I can find it in the system to give you its disposition.
    Mariss
  5. #45
    2010
    Quote Originally Posted by Mariss Freimanis View Post
    jb,
    Mariss
    John Bradford
    Bakersfield, Ca
  6. #46
    jhowelb,
    You really have to try much harder to kill a G203V. Your drive came up as "no problem found". That means there was zero, zilch, nada, nothing, goose-egg wrong with it.
    What was wrong was your return address. The drive came back. Please contact me off list.
    Mariss
  7. #47
    Mar 2006
    97
    Hello maris I believe to have a problem I have buy 3 vampire and already I have installed other gecko previously as the 202, two of these vampire I buy them like I replace of the 202 that I used in another plots the problem is tha first 2 vampire that I buy I connect it without problem and they have functioned well to date but the #3 vampire that I buy a week ago it so happens that when I connect it it functions but when I advance plots it from a side for the other the light of the vampire passes from green to orange this does not pass me with the other vampire wanted to know if is some problem or something that you have added to the new
  8. #48
    2010
    As to the malfunctioning Gecko, it was deemed to be "within specs" and was returned to me presumably without alteration plus an extra new one "as a customer service" because of some confusion in getting the drive shipped.
    The original one is still in the shipping onvelope but the new one is installed and happily functioning as nicely as the other "old" one,
    I'm a happy camper!
  9. #49
    Alain26,
    There is something new. The yellow LED lights when your motor is going fast enough to develop full power.
    Mariss
  10. #50
    Jan 2007
    31
    Merry Christmas everyone!!!
    I May have blown a G203V...
    I have sent a mail to gecko yesteday, but no answer yet (its chrismas time i guess).
    Is there anything else i can do?
    This is my mail:
    Hi
    Im having some problems with one of my G203V's.
    The drive has been working for 3 weeks now, but laitly the motor
    connected has stopped for a secound or two
    and then started again. Now it doesn't work at all.
    When i switch on the power, it doesn't do the same startup prosedure
    at the other ones do.
    The green ligth just comes directly on, and after alittle while the
    red one also comes on.
    I should also mention that it looks like the green and the red ligth
    is weaker than in the other drives.
    I can feel the drive is getting hotter than the other ones, i guess 40C.
    There is no torque in the motor at any time.
    The disable terminal is not connected.
    I have removed the internal fuse and mesured it, it is ok.
    The drive was connected to a 3,25A motor
    Witch if i understand correctly you should multiply with 0.717 to get
    the current in series.
    This means 2,3A.
    My resistor should then be 23k (i have 22k connected, also checked
    that with multimeter).
    To eliminate any problems with the wiring, i changed the drive with
    one of the others
    Now the problem moves with the drive.
    I feel i have done everything i can do alone
    And i would appreciate if you could advise me what to do next.
  11. #51
    Dec 2007
    9
    Talking g203v
    Hi Mariss, I received my second 203v about a week or two ago and it was unfortunately DOA. Being so far away (South Africa) I decided to have a look at it myself. When power was applied, the green LED flashed on briefly then all was dead. While inspecting it I pressed lightly on various components and found that it came to life when pressing a component near the voltage regulator. It was a chip with 2 legs on one side and 3 on the other. On closer inspection (lots of jewellers loupes etc) the solder had a goldish tint and had a sort of matt texture. After murdering a soldering iron with a file I had a small enough tip and managed to re-solder the thing. Happiness!!!! Green and red lights flashed and glowed and steppers turned. Great relief as this would have caused at least a couple of weeks delay. Many thanks for a great product!
    Best regards
    Les
  12. #52
    moxy,
    Sorry about that. ROHS solder doesn't wet as well as normal solder does. It seems one terminal of the SOT-23 was not wetted and was making a cold connection. This happens once in a long while with lead-free solder, never happened with regular solder. I'm glad you spotted it and corrected it. Lead-free solder (Sn 96.5%, Ag 3%, Cu 0.5%) has a characteristic matte finish.
    joakim,
    Please return the drive for evaluation.
    Mariss
  13. #53
    Aug 2005
    828
    I see this RoHs stuff is giving people problems, I think a big breath of LA air is worse.
    Dennis
  14. #54
    Jan 2007
    31
    joakim,
    Mariss[/QUOTE]
    Thanx Marris
    I'll send it today.
    I also opened it, but i didn't see any obvious faults.
  15. #55
    Jun 2004
    6618
    I just sent one back yesterday. With the holidays, it does take some time to get a reply, but the website shows they are closed on some days, so emails don't close and there is likely some catching up to be done when they all get back in the office.
    I got a reply from Marcus.
    He told me what to do with the 203V.
    It is in the mail.
    This one isn't actually fried I don't think, but doesn't function. It still shows a green LED.
    Here is a copy of the email I sent.
    I found out today after thoroughly testing and rewiring, that one of my
    203V's isn't working. I did a swap with another good drive, a 201, and
    the machine is working now. The 201 is out of my router. I went through
    the troubleshooting guide for the 203's on your yahoo Support Group. It
    is getting a green light, so it must be something minor. The fuse
    appears intact. With all power off, I checked across the phases on all
    three gecko's at the pins behind the terminals. I got zero ohms from the
    wires in the same windings and read 97 or some percent of that value to
    the other winding pins. These readings were the same for both good
    203V's. I only read about 75 or some percent of that value across the
    bad one.
    I would like to know how I go about sending this one back for repair?
    I did order two more today. I understand it is the holidays, and I will
    be able to run both machines off of one control box until the others
    arrive. Thanks a bunch.
    Here is an image of how the drives were mounted. I have since changed the wiring around some. Motor wires and PS wires are all a little neater and the switch wires no longer run across the top of the X gecko.
    This bad Gecko was in the Y position initially. I also added more terminal blocks to make the connections better for power and ground from the PS. It BTW is a 72 VDC @ 12 A. It produces lower voltages as the motor amp draw increases I think. Running 3 amp motors with a 35.2K resistor on each drive.
    Lee
  16. #56
    Jun 2004
    6618
    I thought I would update this. I got an email and a notification from Gecko today. It said "Stepper Drive -- Returned for evaluation. An Intermittently working IC was found.
    IC replaced, and drive repaired.
    It's on it's way back @ no charge. Thanks a bunch, Mariss.
    Lee
  17. #57
    Aug 2006
    102
    Question 203s
    i am not sure if mine are blown or what. i had 4 hooked to a new router. i hooked all the commonins to 5 volt. after that none of them worked. no lights on one, green lights on the other three. morris [?] at gecko [the only tech at gecko last friday] told me to return them all. i did. we will see how bad i messed them up. mAYBE, CONGRATS TO ME FOR BEING THE FIRST? greg
  18. #58
    Jun 2004
    38
    Quote Originally Posted by DennisCNC View Post
    Bloody horrible stuff, it's banned in any military application because of tin whiskers. Though now all the standard components are pre-tinned with the stuff we're buggered.
  19. #59
    Aug 2006
    102
    i posted thisin another thread, but wanted to make sure people see it!!
    morris? [at gecko] told me to send in all my 203s [4] to be checked out. i sent them off on jan 3rd got them back on the 10th. 1 had a blown fuse [my fault i wired the comm to 5 volt] the other 3 were ok. i reinstalled them same problem. a call back to morris, he came to say my resisitors were too small! i got some that he told me to get for 33 k [orange, orange, orange] came back & installed & behold it works. i want to give a big thanks to gecko [morris in paticular & mariss also] as they are a great bunch to do bussness with. thanks to everyone who tried to help me with this problem [another great bunch of people] greg
  20. #60
    Jan 2007
    31
    I got my 203v back form gecko yesterday, repaired and sent back free of charge. thanx alot for everything...
Page 3 of 8 12345
  1. X2 column mod- I went over kill!
    By chronic in forum Benchtop Machines
    Last Post: 04-05-2013, 03:47 PM
  2. How not to kill yourself with PVC!
    By fishface in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-22-2012, 01:51 AM
  3. New here. Please do not kill me
    By DMIINC in forum Community Club House
    Last Post: 08-07-2009, 04:52 AM
  4. How do I Kill Merlin?
    By dkaustin in forum Machines running Mach Software
    Last Post: 08-05-2008, 09:35 AM
  5. Big Red Kill Switch, where to get?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 03-23-2004, 05:42 PM
