I just sent one back yesterday. With the holidays, it does take some time to get a reply, but the website shows they are closed on some days, so emails don't close and there is likely some catching up to be done when they all get back in the office.
I got a reply from Marcus.
He told me what to do with the 203V.
It is in the mail.
This one isn't actually fried I don't think, but doesn't function. It still shows a green LED.
Here is a copy of the email I sent.
I found out today after thoroughly testing and rewiring, that one of my
203V's isn't working. I did a swap with another good drive, a 201, and
the machine is working now. The 201 is out of my router. I went through
the troubleshooting guide for the 203's on your yahoo Support Group. It
is getting a green light, so it must be something minor. The fuse
appears intact. With all power off, I checked across the phases on all
three gecko's at the pins behind the terminals. I got zero ohms from the
wires in the same windings and read 97 or some percent of that value to
the other winding pins. These readings were the same for both good
203V's. I only read about 75 or some percent of that value across the
bad one.
I would like to know how I go about sending this one back for repair?
I did order two more today. I understand it is the holidays, and I will
be able to run both machines off of one control box until the others
arrive. Thanks a bunch.
Here is an image of how the drives were mounted. I have since changed the wiring around some. Motor wires and PS wires are all a little neater and the switch wires no longer run across the top of the X gecko.
This bad Gecko was in the Y position initially. I also added more terminal blocks to make the connections better for power and ground from the PS. It BTW is a 72 VDC @ 12 A. It produces lower voltages as the motor amp draw increases I think. Running 3 amp motors with a 35.2K resistor on each drive.
Attachment 49410
Attachment 49412
