586,599 active members*
3,725 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > Importing DXF to Vcarve Pro trial, Profile toolpath seems odd - Help needed
Results 1 to 8 of 8
    Mar 2005
    109
    Im new to CAM and following the Vectric "wing spar" tutorial to setup a Profile toolpath.
    I created a new drawing and imported a dxf of the part I need to cut. After setting up the material, tool, vectors, etc...
    I run the calculate and the path is way off (see image). What do you think im doing wrong? Is there anything specific I need to do in AutoCAD when saving as dxf?
    35538
    Re: Importing DXF to Vcarve Pro trial, Profile toolpath seems odd - Help needed
    In AutoCAD, use PEDIT to make it a single closed polyline.
    Or, In V Carve Pro, use Node edit to change the start points.
    It looks like the different segments are being cut in different directions, so some are offset to the inside, and some to the outside.
    Mar 2005
    109
    Thanks Gerry. When I did PEDIT, the fuzz distance was to small to close the polyline into one polygon.. i didn't notice that initially.
    35538
    There shouldn't be any gaps in the drawing to start with. Accurate cuts require accurate drawings.
    Mar 2005
    109
    Unfortunately, they are not my drawings. Shared in another forum.
    Jun 2008
    562
    Highlight the vector then press "J" (join) and Vcarve will give you the info on those vectors.
    https://docs.vectric.com/docs/V9.0/V...20Vectors.html
    Mike
    Nov 2016
    12
    Did you figure it out? If not maybe include the file so it can be downloaded and evaluated. It looks segmented and it is being cut in two parts.
    Mar 2005
    109
    Quote Originally Posted by dvaskie127 View Post
    Yes, I did. thank you. I opened it up in AutoCad and did a PEDIT as stated above. I need to read the vector document Mike linked to above.
  1. Vcarve PRO trial version question about vector textures.
    By cstmwrks in forum PhotoVCarve and VCarve Pro
    Last Post: 03-12-2015, 07:17 PM
  2. TOOLPATH DOES NOT COMPUTE IN VCARVE V25
    By thos913 in forum BobCad-Cam
    Last Post: 03-25-2013, 03:41 PM
  3. Importing a toolpath
    By Ed from NY in forum BobCad-Cam
    Last Post: 07-26-2009, 09:53 PM
  4. VCarve PRO trial
    By u77171 in forum Vectric
    Last Post: 05-18-2009, 11:04 PM
  5. Trial Version of VCarve Pro available
    By Tony Mac in forum Vectric
    Last Post: 07-07-2006, 10:46 PM
