586,104 active members*
3,292 visitors online*
Results 1 to 5 of 5
    Aug 2005
    36
    scale drawing
    how do you draw something 2x or 3x larger than actual size
    Jan 2006
    4396
    Quote Originally Posted by markjb View Post
    Main Menu Change>Translate>Scale> Enter the Scale you want. Set the Stereo Buttons to what you want as far as Incremental Shifts, Snap Point, etc.
    Cheers!!!!:cheers:
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Feb 2007
    16
    Toby, How would you scale down and make the drawing smaller? The scale box does not allow a minus symbol.
    4826
    Scaling down does not require a negative value, rather it requires the use of a decimal fraction. To scale down 2:1, use a value of .5 in the scale boxes.
    As for the original poster's question, I'm not sure of why one would want to actually change the number of units per side. All computer CAD is drawn at 1:1 as there is no need to incorporate scaling for the purpose of printing the drawing, in most cases, unless you are trying to create a larger than life inset. The printer scale is typically all that might be needed to make something larger than life size.
    First you get good, then you get fast. Then grouchiness sets in.
    Jan 2006
    4396
    To add to Hu's information. Printers today com with a software disk that allows the user to Print sections of blown up Prints. You will have to tape them together but it is possible to make a print that is 24 different sections on 11 by 8 sheets. I just found this in my HP printer Software.:rainfro:
    Toby D.
    Schwarzwald
  1. Need to make scale tire mold for 1/6 scale car
    By thuffner3 in forum Moldmaking
    Last Post: 04-29-2008, 06:57 AM
  2. scale
    By craig in forum Mastercam
    Last Post: 03-09-2007, 03:10 PM
  3. HELP Please Turbocnc 4 scale
    By SCOTTY in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-27-2005, 08:15 AM
  4. The Scale of Things
    By ToyMaker in forum Community Club House
    Last Post: 07-23-2004, 01:48 PM
  5. How do you scale in
    By cncman2 in forum Mach Software (ArtSoft software)
    Last Post: 06-20-2003, 02:24 PM
