586,035 active members*
3,620 visitors online*
    Sep 2017
    "DUAL" Female Thread
    Hello everyone.
    I am working on a project that requires a DUAL Female thread at each end of the shaft.
    Meaning, both right Hand and Left hand bolts will screw into it.
    I know its possible as there is a components that uses this type of thread already i just down know if it has special name or how to draw it or manufacture it.
    I have searched online high and low but can not find any information about this kind of thread.
    I have seen it and can only describe it as a thread that looks like its made out of many scalops and the thread is not continues, so has many breaks in it.
    Here is a link to the product that uses DUAL thread, may be it'll help.
    https://cdn.shopify.com/s/files/1/15...g?v=1484398920
    Thanks very much in advance for idea ye might have.
    Andrei.
    Re: "DUAL" Female Thread
    Just thread-mill the required left and right hand threads, with an optional cleanup of the first one after cutting the second.
  1. How to "Drill" a 1/2-20 thread hole 1" deep on a Tormach in Ti-6Al4V
    By ChrisPhoenix in forum Material Machining Solutions
    Last Post: 07-18-2015, 01:05 AM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Small CNC build thread 20" x 18" x 4"
    By metalworkz in forum DIY CNC Router Table Machines
    Last Post: 01-15-2013, 03:29 AM
  4. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
  5. How do you "connect" dual motor X axis ?
    By Calico in forum DNC Problems and Solutions
    Last Post: 03-17-2005, 08:28 PM
